Tool Talk Discussion Forum
AC vacuum pump
msb
06-11-2005 18:28:19
Looking to buy a new or good used AC vacuum pump.Anyplace I should look? TIA,bob
Big Jim
06-14-2005 00:09:10
 Re: AC vacuum pump in reply to msb, 06-11-2005 18:28:19
If you have access to shop air near the equipment, HF will sell you a venturie vacuum pump for about 15 bucks. It does what I need it too.
Charles (in GA)
06-12-2005 18:06:34
I have an old Kelivnator, cast iron, belt driven, compressor on a heavy stamped steel plate. The motor was gone, I run it with a 1/4 horse off an old diaphgram air compressor my dad had years ago, and put casters under it. It was a drink box compressor, used Sulfur Dioxide for a refridgerant, before Freon was invented. It will pull 28+ inches and works well. Spits out a little oil, so I replinish the crankcase ocassionally.
Charles
Ia Toy
06-11-2005 21:24:57
If you know anyone that used to milk, a milking vacuum pump should be cheap.
thurlow
06-11-2005 20:02:54
I've used the compressor out of a central air conditioning unit for many, many years; only drawback, it can't be used "in the field"; have to have AC current..... .
T_Bone
06-12-2005 17:59:43
 Re: AC vacuum pump in reply to thurlow, 06-11-2005 20:02:54
Hi Bob,
As thrulow stated, used hermetic refrigeration compressors can pull about 28hg and auto refer compressors about 25hg.
You didn't state your vacuum needs but they both work well.
T_Bone
msb
06-12-2005 20:07:29
 Re: AC vacuum pump in reply to T_Bone, 06-12-2005 17:59:43
Thanks everybody.I have an old York unit off a Ford truck that I was going to adapt to the pickup for an air compressor.Guess I can belt it up amd use that.Have a leak in one of the 4430 tractors.It leaks out in a day of setting so it shouldn't take a genius to find it(thank heaven lol)I have already converted it over to R134A. Thanks T bone ,bob Now to find a vacuum gauge.
