Tool Talk Discussion Forum
Pressure washer question
Jay87T
06-09-2005 11:55:33
Hey guys Im looking to buy a new electric pressure washer, I had one that had a soap resivoir but the soap would only come out on a low pressure setting on the pressure washer, Im looking for a pressure washer that will shoot the soap at high pressure with the water, is this called "detergent Injection" I see that on some of the pressure washers, or is that just the same thing as my old one?
RayP(MI)
06-09-2005 15:28:59
 Re: Pressure washer question in reply to Jay87T, 06-09-2005 11:55:33
Typically, manufacturers prefer to inject cleaning solutions downline from the pump. This prevents chemical damage from the solutions that might be sent thru.
Ron from IL
06-10-2005 08:25:46
 Re: Pressure washer question in reply to RayP(MI), 06-09-2005 15:28:59
The injector system that I described IS a downstream injector. It screws on inline just ahead of the spray hose. You just have to watch how strong of a soap solution that you mix up--it can get really foamy!
Ron
Ron from IL
06-09-2005 12:33:40
Jay,
It's hard to find a pressure washer like you want for a reasonable price. That being said, you CAN buy an aftermarket add-on injector from Northern Tool for around $30 that will do just what you want. I bought one last fall for my pressure washer, and it works just fine. Now, you can buy a less expensive pressure washer and still get "power suds".
Good luck!
Ron
