Tool Talk Discussion Forum
Welding Helmet Recommendations?
PaulW_NJ
06-08-2005 20:43:44
I know the subject of auto darkening helmets has been beat to death. I"ve decided to get one, and frankly I"m more than a little apprehensive to buy a cheap imported one. At the same time, I don"t want to give much more than $200. I would like the larger window, if possible, as that is what my manual one has and I"m kind of spoiled by it.
Haven"t welded for awhile, but have a bunch of projects that require it. I"m convinced the autodarkening will help make it easier.
I"d appreciate recommendations for manufacturers and features, based upon your experience. Since most all of my work will be indoors, I imagine I"d want replaceable batteries. Any help and suggestions would be really appreciated.
Stan in Oly, WA
06-09-2005 12:54:21
 Re: Welding Helmet Recommendations? in reply to PaulW_NJ, 06-08-2005 20:43:44
Hi, PaulW
Jackson is the only American company who makes their own auto darkening units. Low end helmets probably use Asian optics, high end might use Swedish, but I'm only speculating.
Speedglas is the original and may still be the best. Swedish made, Swedish technology, very, very, very nice helmets. Did I mention spendy? They are.
The advice that you won't get a large window in the price range you set is correct. Maybe you don't need it. I went from a large window standard helmet to a standard (small) window auto darkening one. The improvement is so enormous that the minor issue of a smaller viewing area got lost in the amazement.
A friend gave me my first auto helmet several years ago. About a $50 helmet from e-bay. I didn't think there was anything wrong with it until I tried a different helmet and realized that mine was a little slow coming back to the clear state.
I bought myself a Jackson something or other, for $140 from Welding Mart online (free shipping and no tax.) It has a lighter clear state than any other helmet I know of (shade 3, I think) and recovers really fast. But now it's my good helmet, so I only wear it when the Pope drops by.
I picked up a $50 HF special to see if it would get back to clear faster than the original knockaround helmet. It does. Nothing wrong with the optics, but the cover plate is a strange size so I always have to cut a little off a standard one when it needs changing.
There's still lots of argument about whether the lag in darkening eventually hurts your eyes. Okay, so twenty thousand starts is like looking at an arc for one second. Your mileage may vary. My experience is that using a standard helmet, I flashed myself at least once per hour of actual welding. Now i never do. I'm almost 60 and I don't wear glasses. I can read fine print if the light's good. The eye doc said my eyes are in perfect condition. My .02
All the best, Stan
big fred
06-09-2005 15:04:10
 Re: Welding Helmet Recommendations? in reply to Stan in Oly, WA, 06-09-2005 12:54:21
If it meets the ANSI spec, it protects you against the UV and IR even before it switches to the dark state. The darkening feature affects the transmission of light in the visible spectrum only.
T_Bone
06-09-2005 12:25:09
Hi Paul,
You can read my response down the page on autohoods but if I was going to buy one, I would only buy a Huntsman hood. Huntsman makes the finest of welding hoods.
T_Bone
chvet73
06-09-2005 07:17:42
Go to Quimby weldings EBay store. They have several Millers for $150-200. I got the plain black one and it is great. You will not find the wide lens in your price range.
Waltertn
06-09-2005 06:52:11
I use the Hobart hood. It has a battery, sensitivity to darken adjustment, adjustment for time to lighten, and an adjustment for how dark the shield is (9-13). Was around $160 and has an 18 month guarantee.
Coldiron
06-09-2005 05:26:23
Paul, If you have a limit on cost I would go for the one that would give me the widest range of adjustments for the money. Don`t forget to leave enough money to put a sheepskin sweatband (and maybe cheaters that will magnify your work). Great improvements to any hood if you are going to be wearing it for any length of time. Hope that you like your new hood as much as I like mine.
PaulW_NJ
06-09-2005 19:01:18
 Re: Welding Helmet Recommendations? in reply to Coldiron, 06-09-2005 05:26:23
Thanks to all of you for your responses and suggestions.
Rauville
06-09-2005 06:02:44
 Re: Why not handheld shields? in reply to Coldiron, 06-09-2005 05:26:23
In regard to "wearing" a welding helmet; why not a handheld shield? For stick welding, I've always preferred one over the wearable helmet. It seems so much faster and easier to check your work, and positioning your rod for starting. Generally, you only weld with one hand...why not put the other one to use?
Coldiron
06-09-2005 07:28:59
 Re: Why not handheld shields? in reply to Rauville, 06-09-2005 06:02:44
Rauville, I use the handheld sometimes but the handle on mine is not positon adaptable for the cheaters to be in line with my eyes and sometimes the holding positon is not comfortable doing overhead so I opt to use the helmet most of the time. Guess it is what you are comfortable with. I will use a handlheld if I am just doing short welds or tacks since it is faster.
