Tool Talk Discussion Forum
Building a Trailer
Glenn F.
06-08-2005 15:07:12
Generally how much would a person save by building their own tandem bumper hitch trailer, assuming I would have to buy all new materials. Anyone have a bit of a breakdown as to what it would cost to build a 12,000# deckover, approx. 16' long with a 3' beaver tail and 102" wide? The only materials I have on hand is the lumber for the decking. Am I ahead to just buy a new one? Thanks, Glenn F.
MMRTI
06-10-2005 06:17:18
 Re: Building a Trailer in reply to Glenn F., 06-08-2005 15:07:12
I agree with the previous comments. Friend who is a welder built a 5th wheel trailer. He had plans and was able to shear some parts at work. Trailer got too heavy when done. He also bought surplus steel of unknown quality. After modest use trailer developed stress problems. He went and bought a factory trailer and has had no problems. Brother bought a 12,000 bumper hitch trailer. After 5 years of pretty heavy use there is no problems with it. Have a nice day
Galen
06-09-2005 20:00:31
B-I-L just built a trailer to haul his yuppie tractor. By the time he got it all said and done - it was about $3500 for an 18' tilt bed. Could have bought the same thing for $1900.
T_Bone
06-09-2005 18:28:12
Hi Glenn,
I bought this 32ft GN trailer last Friday for $200 less than my material cost. About the only difference is I was planning on a steel deck where this one has a wood deck. Check around in Texas as even with shipping you can't beat there pricing.
T_Bone
Anthony
06-09-2005 09:42:13
You would need a good set of plans, or even better copy the design of a good name-brand trailer. There are so many variables in the weight and type of steel, placement of crossmembers, hitch design, keeping everything aligned, etc. In the end I don't think you could save any money; what you save in labor you will spend in materials and it is still your labor.
Do you really think a 3' beaver is enough? Unless you are always loading/unloading in a specific spot that is not much for the height of a deckover. Most good commercial units are 4-5', but I don't know, what do others think?
Dale O.
06-09-2005 08:29:50
If you have a set of professional plans and a cheap source of raw material, you MIGHT be ahead of the game. What happens with most home-builts is, as some others have said, they get "over-built" and end up weighing more than they should for what they haul. This cuts into the actual capacity of what you can haul. for instance, if your tow vehicle is rated at 8,000 lb and the trailer weighs 3,000, you would (by the book) only be able to carry 5,000 lb.
Jeff Wenner
06-09-2005 02:31:00
I don't know where your located but there is a place just accross the PA line in Ohio that will build you an excellent trailer cheaper than you can do it yourself.
http://www.appalachiantrailers.com/index.htm
big jt
06-08-2005 23:07:12
From what I saw 12 years ago when I bought a 5th wheel there is no money to be saved building your own. Don't think this has changed due to steel prices if anything it would cost more to build your own.
Only reason I could see to build my own was if I couldn't get just what I wanted on the market. There is just too much competition in this area so they all chisel their suppliers to get costs down to be a little cheaper than the next guy.
I would suggest looking at the trailers close to make sure you get the basic structure you want. Seemed like most of the companies make their money on the add ons. I bought a 20' deckover, gooseneck with tandem singles, 5' tail with two ramps for right at $4000 in 93'.
Took it home and right away backed it in the shop and took a torch to it. Reworked the two ramps so they would work with a loading dock. Added a center ramp. Chain racks etc. Most of all put on a hydraulic winch powered by a 5hp briggs that will drag just about anything the trailer will haul. Spent about $1000 to $1500 on these mods but in my looking I think the company I bought from wouldn't have done it the way I wanted and to get close would have cost me over $3000 extra.
All in all my advice is buy the base trailer if you can get what you want and then do your own add ons.
JM2CW
jt
RWK in WI
06-08-2005 17:40:00
Be careful, In some states you can no longer resister a home built trailer unless it is designed by an automotive engineer, welded by a state certified welder, and inspected by a state certified inspector & trailer mechanic. It could be cheaper to buy.
thurlow
06-08-2005 15:37:03
third party image
Can't give you any specifics, but I've built several. Since my materials (except for flooring) are bought at retail and I tend to over-build, most times it would have been cheaper for me just to have bought one. Doesn't stop me, however; just like designing and building "stuff".
Glenn F.
06-08-2005 17:32:52
 Re: Building a Trailer in reply to thurlow, 06-08-2005 15:37:03
Where do you live Thurlow? Looks like pretty country. I tend to overbuild too. The homebuilt stuff is always better! Thanks, Glenn F.
thurlow
06-08-2005 19:01:06
 Re: Building a Trailer in reply to Glenn F., 06-08-2005 17:32:52
Lauderdale County, Tennessee, 'bout 50 miles North of Memphis. Weeds and kudzu tend to overrun the yard, as evident in the picture; just draw a (theoretical) line and say I'll mow to here and you can have the rest..... ...
Van in AR
06-08-2005 20:44:00
 Re: Building a Trailer in reply to thurlow, 06-08-2005 19:01:06
Thurlow,
Just spent a couple of weeks at Memphis working elevator legs at the Cargill plant on Presidents Island. Im west of you about 4 hours, great country there, did a couple of evening road trips to your part of the world, just seeing the sights, love that part of Tenn.
Van
