Tool Talk Discussion Forum
Lincoln portable welder
Dale in Ar.
06-08-2005 09:26:43
I just got a used portable Lincoln and it works ok.The only problem I have for now is the motor mounts.They are broken,all of them,and I need to get new ones.I went to the Lincoln web sight but there was no listing of parts to order that I found.Also they did not list this welder but one similar but no parts for it either.I have a power Arc 4000.Where can I find parts on the web or other places ???
Joe(TX)
06-10-2005 08:54:21
 Re: Lincoln portable welder in reply to Dale in Ar., 06-08-2005 09:26:43
Lincoln has their manuals in pdf format on their website including parts.
Find the manuals page and wade through until you find the right one. It should give you the part number.
Fred OH
06-09-2005 08:21:39
I had a Hobart welder that had both motor mounts busted (the rubber had pulled away from the metal) and someone had done a field repair on it by putting a piece of chain around the mount so it couldn"t go anywhere....welded with it for years like that. Sometimes you just don"t need to worry bout the mule goin blind...just load the wagon. Fred OH
Richard Fazio
06-08-2005 15:27:44
Anything you need for that welder is available. The lincoln site does have parts breakdown sheets and you can order from them direct. Lincoln is one of the better companies to deal with, they will take care of you. If you can't find what you need on the web site give them a call. They will tell you how to find it and will help you order.
lucasss
06-08-2005 09:33:24
louisville welding can get anything available for linoln welders. 502-584-8964 ... lucas
