Tool Talk Discussion Forum
Remove broken off bolt
meadows
06-07-2005 10:13:13
Ive got 2 bolts broken off in the housing of my MF 50. They used to hold the chain for the 3 pt hitch arm. Any advice would be appreciated. thanks Lou
JT
06-08-2005 06:27:40
 Re: Remove broken off bolt in reply to meadows, 06-07-2005 10:13:13
Take a torch and blow the bolt out of the cast iron housing, it works, neighbor does it all the time with good luck, expecially on head bolts.
dr.sportster
06-07-2005 13:56:16
Yt archives has alot on this besides the good advice these guys have given.I originaly found this site by google searching "broken stud" and Ive been given good advice ever since.Probably even gave some bad advice many times to show my appreciation.
JoeMN
06-07-2005 12:39:09
Blow it out with a cutting torch. The slag can be turned out with a screwdriver. Don't overheat or you'll damage threads in the housing.
MAC,IL
06-07-2005 11:25:10
Once in a while in that situation, I get lucky using PB Blaster and lightly tapping the bolt. Then work it out with a good center punch far nuff to get a hold of it.
kidbob
06-07-2005 10:21:43
What I try first is good penetrating oil, then hold the right size nut over the bolt and weld in the center (wire feed works best). Some times I weld on 4 or 5 before I give up.
farmermatt
06-07-2005 11:59:18
 Re: Remove broken off bolt in reply to kidbob, 06-07-2005 10:21:43
Id do the same but (knock on wood) Ive never had top give up. I think the most nuts Ive had to weld before breaking it loose is about 8. Probably used this method 2 dozen times.
Bernie in MA
06-07-2005 17:35:44
 Re: Remove broken off bolt in reply to farmermatt, 06-07-2005 11:59:18
What I've done is weld a flat washer on first, then weld a nut to the washer. That's worked good for me.
Woodrow Caul
06-07-2005 20:40:48
 Re: Remove broken off bolt in reply to Bernie in MA, 06-07-2005 17:35:44
weld is best but you will have more success if you will weld a cone shaped ant hill to the bolt first. The additional heat this creates will break loose rust and give more penetation for the weld to hold to the nut. Most guys dont get enough heat on the bolt and tear a chunk out with the nut. After you make the ant hill slide the nut over like a wedding ring and weld. Let cool but not cold.
