Tool Talk Discussion Forum
Wheeling Bearing Grease???
Woodsman
06-02-2005 19:05:17
Is the grease used in grease guns the same as that used to pack wheel bearings? Thanks.
Galen
06-04-2005 22:06:31
 Re: Wheeling Bearing Grease??? in reply to Woodsman, 06-02-2005 19:05:17
Odd - he never did say he was using it on his TRACTOR - just wheel bearings.
Old Dutch
06-04-2005 11:49:27
Woodsman check this out
Link
Hope that helps.
Dutch
Slowpoke
06-03-2005 01:02:00
Maybe yes, maybe no. It all depends on what has been put in the gun. Go to the auto parts store and you will find several different kinds of grease in tubes for a gun, and you will probably find a few of the same types in cans for manual application. There are many different greases and the rule is: don't mix different greases in a bearing. If you don't know what has been used, remove the bearing and clean it, then grease with the correct type. Most of the tubes and cans will state the type of grease on the label. Usually common lithium base is used for wheel bearings, except for disc brake bearings which need High Temp grease.
Van in AR
06-02-2005 23:42:05
You can get EP (extreame pressure grease) in a can or in a tube. A tractor front end bearings could be packed with regular gun grease due to the low speeds and low heat build up.
Van
Leland
06-02-2005 19:47:25
I statrted using marine wheel bearing grease for every thing and it comes in tubes good stuff won't wash off or fling either.
Slowpoke
06-03-2005 01:08:15
 Re: Wheeling Bearing Grease??? in reply to Leland, 06-02-2005 19:47:25
Isn't that stuff like stepping in chewing gum on a hot day?
Leland
06-03-2005 05:57:18
 Re: Wheeling Bearing Grease??? in reply to Slowpoke, 06-03-2005 01:08:15
yes it is but it takes heat well and it stays put.
Galen
06-02-2005 19:12:46
Most likely not - you need High-temp wheel bearing greas for bearings. Any auto parts store should have it.
Roy in UK
06-02-2005 22:44:42
 Re: Wheeling Bearing Grease??? in reply to Galen, 06-02-2005 19:12:46
Quite a lot of Tractors e.g. MF have or at least had, grease nipples ( zerks? ) in the front hubs so you could grease the wheel bearings with a grease gun, so there you are!
dhermesc
06-03-2005 11:15:50
 Re: Wheeling Bearing Grease??? in reply to Roy in UK, 06-02-2005 22:44:42
True, but tractor wheel bearings are not building up near the heat due to lower speeds. "Regular" grease in an automotive application with disc brakes will melt away in no time.
