Tool Talk Discussion Forum
Diesel Compression Tester
Rich K
06-02-2005 12:49:19
I am looking for a diesel compression tester to be used on my MH Continental engine. I guess it requires a special adapter for this engine. Does anyone have such an adapter or found a kit that will work with this engine? Thanks.
dtanner
06-02-2005 22:32:13
 Re: Diesel Compression Tester in reply to Rich K, 06-02-2005 12:49:19
Howdy, I bought one from the local napa dealer for $130 that has several adapters for different size injector holes. Shop around. good luck
e
06-02-2005 19:14:33
Did you check the kit sold by harbor freight? For $149 you can get every adapter under the sun including odd ball engines such as Puegots(sp?) etc.
E
george md
06-02-2005 18:20:10
Rich,
I should have one .
george
J. Schwiebert
06-02-2005 18:18:48
Before you spend money for a diesel compression tester why not do a cylinder leak down test/ Why do you want to do the compression test.
Rich K
06-03-2005 04:24:13
 Re: Diesel Compression Tester in reply to J. Schwiebert, 06-02-2005 18:18:48
I am curious to see what kind of compression this old engine still has and if the reading is the same on all of the cylinders. If it's off, then I will do the leak down test. Thanks for the replys.
NC Wayne
06-02-2005 18:12:27
I don't know what kind of injectors your engine has but if you can't find a suitable adapter I've had good luck making them out of old injectors. It usually takes a little time and machine work to get them fixed where you can hook your tester to them but it's at least an option if you don't find anything else. Good luck.
