Tool Talk Discussion Forum
another well question ???
Bryan In Iowa
06-02-2005 11:28:18
We have old well at cabin . There was no pressure tank or cut off switch on this. submersible pump, just trun breaker on when needed water ,,shut off when done . I installed pressure /bladder tank and switch . Tried it out , pumped up & shut off ok . Now I am hearing a tic or click out of the disconnnect box. This was never heard before because of simply just turning off breaker when needed to shut off . Is it bad capacitor ? Only makes noise when pump shuts off. I ran one of each hot wire to switch contacts , and left yellow wire alone. Is that right ?? Thanks Bryan
ccwken
06-02-2005 19:02:26
 Re: another well question ??? in reply to Bryan In Iowa , 06-02-2005 11:28:18
It's probably the start capacitor relay. It's purpose is to kick in the start capacitor then bypass it. It sounds like you have the control box wired infront of the pressure switch. It should be the other way around.
There should be a circuit diagram on the inside of the control box.
Line in-->Pressure Switch-->Control Box-->Pump
