Tool Talk Discussion Forum
Two-cycle engine won't rotate
KD
05-31-2005 11:33:22
I was using my Craftsman chainsaw (40cc, 2-Cycle engine)this weekend and it was running normally. After a refueling I was unable to restart it. The pull cord was extremely difficult to pull and it only extended a few inches. But if I remove the spark plug the engine spins freely when I pull the cord. I am guessing that I might have a stuck reed valve. Does this engine have a reed valve? If it does how would I check it?
ScottP
06-01-2005 11:07:50
 Re: Two-cycle engine won't rotate in reply to KD, 05-31-2005 11:33:22
KD
Check the spark arrester on the muffler. It may be plugged up. To clean it, remove it from the muffler and heat the screen with a propane torch, then after it cools use a wire brush to remove the
loose ash.
Scott
Coldiron
06-01-2005 06:02:42
Loaned my chainsaw to a neighbor, gave him the gas can full of mix and a jug of bar oil. He ran it for a while. He returned it and said it was hard to crank. I let her sit a couple of days and went to use it and it would not crank. The rope would only pull out a couple of inches. Pulled the plug and the cylinder was full of BAR OIL. The bar oil tank was full of gas. Took a while to clean everything up and she was ok. Oh yeah, he was very proud of his certificates from small engine schools ! LOL I stopped lending tools that day.
Harry1
05-31-2005 18:17:38
My friend grabbed the wrong fuel jug and filled his chainsaw up with straight gas and locked it up. Made me think of this when your problem started after a refueling.
