Tool Talk Discussion Forum
Manual log splitter report
Ludwig
05-30-2005 15:33:04
Some of you might remember a couple months ago Dad and I picked up a manual 10 ton log splitter from one of those Cummins traveling tool shows. We've got a little camp with a wood stove and burn maybe 1/4 cord a year on trips there. I didn't want the expense of a powered splitter but some of the larger rounds, particularly poplar can be tough to split with the axe.
Its basically a regular splitter with a bottle jack for the force. The jack has 2 handles one operates a smaller cylnder. So you use both handles until the larger cylnder is too hard to work and then you use the smaller one until the wood starts to split and then you can use both again to complete the split.
Well my last trip up was 9 days long and I split at least a piece or two of wood every single day, some days we did a bunch of splitting, probably did just under 1/4 cord (I'm trying to get ahead) in that time. Mixture of poplar that had been sitting on the ground for a year, fresh white birch, fresh and standing dead silver maple and some crazy unsplitable wood that has a grain that twists.
First the unsplitable wood continues to be pretty much unsplitable, it'll shred but never really split.
The old poplar split easy, even the bigger 10-12" rounds that were a pain with the axe, even when it was freshly rained on, and we've had ALOT of rain recently.
The maple all split easily. The standing dead was very easy. We even had a race and it was hard to split it with an axe because the splitter just had to ease up to it and it would split, just setting up took more time with an axe and with the splitter you could do it all sitting down.
The birch was more difficult but still no big deal, the strands inside it tend to hold together tightly so some "manipulation" was needed to get the pieces apart.
On the whole for $100 I'm very pleased even if it only lasts one or two seasons its made things alot easier. We still used the axe, sometimes we'd cut the wood too long or two short for the splitter to work well or the fibers in the birch would be too hard to pull apart. My wife and I took turns, one on the splitter and one with the axe and we could process quite a bit of wood quickly. I'd think it would also be handy during cold weather you could split inside or if you were too sore or whatever to swing the axe.
vinnie
05-31-2005 15:08:50
 Re: Manual log splitter report in reply to Ludwig, 05-30-2005 15:33:04
wood splils the best on the cold cold days
MLP
05-31-2005 07:30:08
Glad to hear that it is working out for you with that splitter. I spent 2.5 hours on Sunday and 2.5 hours on Monday splitting wood with my 12 pound mall and it looks like I should be done in another 20 hours or so of work. I have to split a minimum of 10 full cords a year. The wood I split runs from popular to fence line elm. on the really bad pieces I break out with the wedges and the 16 pound sledge hammer and even then it some times takes 45 minutes to split one piece in half.
I usually get good deals on wood because I will buy the stuff that no one else will touch. I actually like beating the wood in to submission. I do have a splitter with a 5" ram on it but I can do it by hand faster and I still have to do the hard ones buy hand any ways. I did find that it was helpful on the short or stringy ones to run it up as far as it would go then back off and slip in a another short one right behind it to force it all the way past the wedge.
