Tool Talk Discussion Forum
Deutz engine F3L912 Cylinder Sealant?
tezmo
05-29-2005 03:03:43
Hi there,
I am working on a deutz F3L912 engine & need to know when you fit a new cylinder to this type of engine do i need any sealent applied to where the shim sits to prevent oil leakage, also in regards to shim size what size shim do i use or would it be whatever size was already used.
Look forward to your reply,
Regards,
Terry
856 puller
05-29-2005 12:39:22
 Re: Deutz engine F3L912 Cylinder Sealant? in reply to tezmo, 05-29-2005 03:03:43
you dont need any sealent to be sure about the shim thickness you need to measure the piston to head clearence. put a couple different size shims under the jug. take some solder and lay it across the top of the piston. put the head on torque and degree it, you dont have to go all the way, roll it over and take apart and measure both ends and averge readings. hopefully it will be right or to big if to biglift jug slightly and cut the right amount of shims out and recheck. i put rings on and put it together with extra shims it is a little faster than takeing it all apart. email if you need specs i have them around somewhere
