Tool Talk Discussion Forum
OT: Sealing Bricks
RobinPA
05-25-2005 18:08:42
Finishing up fresh masonry work on front porch. Was wondering what is best method/product for sealing the new bricks to guard against weather. Want to make sure no water gets in there to freeze and make them bust. Thanks
MAC,IL
05-25-2005 18:36:08
 Re: OT: Sealing Bricks in reply to RobinPA, 05-25-2005 18:08:42
I seal with thompsons, use an old garden sprayer. I am sure there is a better product out there. Seems thompson is only good for a couple seasons.
RobinPA
05-27-2005 18:16:55
 Re: OT: Sealing Bricks in reply to MAC,IL, 05-25-2005 18:36:08
Thanks MAC. I've had pretty good luck with Thompsons for other projects but did not know they made a brick seal. I'll check it out and probably go with that. Thank you.
T_Bone
05-28-2005 08:50:27
 Re: OT: Sealing Bricks in reply to RobinPA, 05-27-2005 18:16:55
Hi Robin,
I'm not a brick mason so I have limited knowledge but adding 1/4tsp of liquid dish soap to your mortar mix, in the mixer, will break the surface tension of the mortar componets making it more water tight.
I have no idea what to put on already installed bricks. I would call and talk with a brick yard supplier to see what they recomend.
T_Bone
RobinPA
05-29-2005 19:10:36
 Re: OT: Sealing Bricks in reply to T_Bone, 05-28-2005 08:50:27
Thanks for the info TBone. I have never heard of the dish liquid work. If I lay brick on another project I'll keep that in mind. Thank you.
