Tool Talk Discussion Forum
8n carberator
potlicker
05-24-2005 14:31:53
I"m wondering if anyone has some advise on adjusting my 8n carberator. It seems to be running real rich with some black smoke at the exhaust. Any suggestions?
NEsota
05-26-2005 07:25:39
 Re: 8n carberator in reply to potlicker, 05-24-2005 14:31:53
Once, this time of year a mud-dobbers nest obstructed my N's air in-take, ==> black smoke.(c)
Farmered
05-26-2005 00:39:45
With the engine warmed up open the throttle all the way, turn the load needle in (right) until it starts to run rough then back it off about a quarter of a turn. You could also use a vacuum gauge and adjust for the highest reading. Remove the 1/8 pipe plug in the intake manifold to attach the gauge. You may adjust the idle needle in the same way only with the throttle fully closed. With a little practice listening to the engine you won't need a gauge. Ed
Bob66
05-24-2005 15:33:53
Mine was doing that and I gave the main needle 1/4 turn in and cleared it up. Maybe your float is sticking a little.
