Okey-dokey, here we go: After considerable thought, and peeking at the balance in the ol' checkbook, here's how I plan to do it. Prime mover will be a Briggs and Stratton 11 hp electric start twin. Entire assembly will be on a cart, which will be chained to a deadman, and used to haul a tri-hull catamaran sailboat out via a marine railway. I will put a shaft mounted centrifugal clutch on the motor, and chain-drive with a 4:1 reduction to the input of a compact car transmission. My research indicates that 1st gear on most car transmissions run between 2.5 and 3:1. The output shaft of the trans will be gear-and-chain to the input of the winch, 4:1 reduction. The winch has a 25:1 planetary reduction. Thus, with the transmission in first, assuming a 2.8:1 first gear, drum speed on the winch would be 4 RPM, with the engine running at rated speed of 3600. That gives me approximately 10 FPM line speed. That should give me plenty of grunt. If faster line speed is desired, the transmission can be shifted. In high gear at 1:1, I get a line speed of about 30 FPM. The transmission also gives me the option of power out. The winch has a band brake and a ratchet brake. Sure hope this works...
