Tool Talk Discussion Forum
Well water GPM
HarryG
05-22-2005 14:53:44
Just curious whats a reasonable good GPM for a deep well (400") ? Is 4 GPM adequate?????
Coldiron
05-22-2005 19:13:10
 Re: Well water GPM in reply to HarryG, 05-22-2005 14:53:44
HG, Wife, myself, three horses, bunch of pets, lots of plants, bushes to water and had 2 gpm for 12 yrs with no problems. 6" casing, 330' well with pump at 225'. The water would rise to 56' from the surface with 12 hours of no use. Used a 1200 gal holding tank with jet pump to supply house/barn hydrants. Well discharge had 2 gpm orfice restrictor to feed the float control in the holding tank.
Bus Driver
05-22-2005 18:33:51
Here a 6" well is the norm. I have one 610' deep yielding one GPM. Static level of about 60'. The well casing has about 1 1/2 gallons volume per foot of length, so the well stores about 800 gallons ready for use. Water comes into the well while it is being pumped out, but slowly. There have been at times 4 families supplied by the well with no problems.
T_Bone
05-22-2005 16:04:51
Hi Harry,
4gpm is alittle shy for domestic animal use with 4people but with good well mamagement can be used effectively.
It all depends on how much static head the well has and at what deapth the pump is set. Static head is how much water rises in the well casing from it's source.
Lets say you have 100ft of static head on a 400ft well with a 4" bore with the pump set on the bottom (not real but 75ft would be). That's 65gals of water in 100ft or about 1gpm so you have 3gpm of water flowing into the casing yielding ruffly 240gph.
So if you pump your 240gph into a holding tank then pressure pump to feed the house and out buildings at 12gpm, you could last 20min without refilling the tank from the well.
There will be more water available from the well in the early morning hours than in the late evening hours due to the effect of the moon, the same reason that makes tides move.
So if you increased your storage tank size and pumped for a longer time in the mornings, then you would have more water available than direct pumping a 4gpm deep well.
T_Bone
gahorN
05-22-2005 22:43:24
 Re: Well water GPM in reply to T_Bone, 05-22-2005 16:04:51
T-bone, I need a little help with that one. Since the moon-rise/set times drifts over the course of a month...how can "early morning" etc. hold true?
T_Bone
05-23-2005 07:32:45
 Re: Well water GPM in reply to gahorN, 05-22-2005 22:43:24
Hi gahor,
Ya I should have worded that different as you are correct.
The point I'm trying to make is working with a 24hr pump controller, a morning pumping schedule will generally yield more water than afternoon pumping in most areas.
T_Bone
T_Bone
05-23-2005 13:55:20
 Re: Well water GPM in reply to T_Bone, 05-23-2005 07:32:45
Hi Harry,
Another consideration of using a storage tank and pressure pump management, about $500 cost new, is to replace a 400ft deep well pump and labor is about $1800 (here in AZ), where as to replace a pressure pump is $200 or less that can be replaced without a labor charge if your into that kind of repair (knowledgeable).
T_Bone
Coloken
05-22-2005 15:46:52
Just livable. Rough figures... a poor garden hose about 3gpm, good 5 or 6.At 4 you will be lucky to run a lawn rainbird very well. The thing here is if the "pump" can pump 4 gpm for long periods, your ok. If the "well" is only good for 4 gpm, then you have to "choke" down the pump to less than that, or only operate it in short bursts. I have a nice shallow well that can just hold 3 or a little less. It was great with a windmill. I changed over to a submersible and chocked it down to what it can handle. Don't like it at all now.
