Tool Talk Discussion Forum
Suggestions for stainless steel mending.
Gene Davis (Ga
05-21-2005 07:27:05
This is a question for some of you guys like maybe T bone or some of the other gurus. My wife has a nice but very old,(almost 40 years),set of S.S. mixing bowls. Think maybe they are made of 302 or 304 grade material don't think they are the low carbon grade material either. all markings have long since worn away if they were any at all,m and they are about 3/32" thick. The other day, I like a dunce stuck it in the microwave oven for just an instant and true to form it arced a little bit and now has a tiny pin-point size hole in the bottom. The microwave survived with only a tiny black spot on the turn table. She had a king-size fit though. Enough about the stupidity now. My question is this. Could I take something on the order of silver solder, or maybe sil-phos(sp?) and fill the hole,polish it down and will it be food safe? It will only require a drop of either. Anybody have a suggestion for getting me out of the dog house? They were a wedding present and she likes the size of it for mixing up things with the mixer. Of course they are no longer available on the replacement market, that would be too easy. Any body got any ideas. The repair needs to be food safe. Meanwhile, I am in the dog house big time as well as feeling stupid for doing it. Thanks for any help you can offer. Gene
dr.sportster
05-22-2005 11:02:48
 Re: Suggestions for stainless steel mending. in reply to Gene Davis (Ga.), 05-21-2005 07:27:05
I have some TIG type rod thats almost pure nickle.If you need a stick[for free]let me know.I have welded holes in car trim back up with it and it polishes better than the base stainless.It was 35 bucks a pound .You are welcome to a 3ft stick of it if your weldor needs it.[1/8" thick maybe]
Gene Davis (Ga.)
05-22-2005 21:07:34
 Re: Suggestions for stainless steel mending. in reply to dr.sportster, 05-22-2005 11:02:48
Hey guys thanks for all the ideas. Am going to see which options is more doable. Don't have a tig outfit. just stick, MIG, and acetylene. Gene
T_Bone
05-21-2005 22:47:41
Hi Gene,
Your going to have to make sure your working with 300 series SS. I bought the wife some SS cookware 40yrs ago and returned it as it was 400series SS (magnetic) and will rust under the correct conditions.
15% silver solder should work on SS but I've never tried it. If you want to try this method of repair I'll pre-test it on some 300series SS I have and give you the results. I don't have any 400series SS.
Although SS can be low temperature soldered, I strongly discourage this method as it takes a special acid mix with 60/40% lead solder and since it's a NSF appliance you don't want to use any type of lead filler. SS is a real pain to seal solder like you can glavanized metal. In my mind I'm saying don't use a tin solder but I don't know why. I'll think of why latter.
Tig welding would probely be the ideal process with very low Oxy/Acet flame being a good second choice.
Use rubbing alcohol inside and out before starting. This removes all oils.
In any event you need to preclean the SS to "white" metal with a "new" SS power wire brush, then use rubbing alcohol inside and out (removes oils), then use a clean tight fitting copper chill bar on one side of the joint, then weld, then finish.
To finish, blend using air tools if possible running at about 1/2rpm of tool rating or about 750rpm max, then flapper wheel using several grits, then hand finish with scotch brite pads to blend final finish.
You can wrap a piece of scotch brite pad, Red pad would be a good choice with green being 2nd choice, around a wooden dowl pin chucked into a drill motor for a helping hand.
If you don't want to refinish the enitre bowl bottom, use a piece of masking tape to make a even ring around the bowl, finish then remove tape showing a distinkive grain look to 1/3 to 1/2 of the bowl depth that looks good.
As the other guys suggested, trial and error on a used bowl would be inorder.
T_Bone
Davis In SC
05-21-2005 19:23:34
Don't feel too bad about it, you should be able to get it tig welded... If all else fails, send it up here & I will get the tool welding shop in NC to do it my next trip up there. They even do some welding under microscopes.. If this were a hundred years ago, you could just wait until the tinker made his rounds, & get it repaired then. I buy & sell some old stuff, it is not unusual to see old pots & pans that have been patched & mended. I have even seen several that had patches riveted in place..... ..
Ralph - Ohio
05-21-2005 18:24:04
Another Idea
Is this one of the bowls that fits on the turntable of a Sunbeam Mixmaster mixer? If so I think they are still available from a place in Canada where I got some parts not too long ago or probably even on Ebay.
If I was trying to fix it I'd have a much bigger hole when I was done!
Gene Davis (Ga.)
05-22-2005 20:54:49
 Re: Suggestions for stainless steel mending. in reply to Ralph - Ohio, 05-21-2005 18:24:04
Wish it were a Sunbeam bowl, I could just buy another one and substitute it.
Ralph - Ohio
05-21-2005 18:16:26
I know how you feel having been in that situation myself more than once. If you decide to replace the bowl, Lehman Hardware in Kidron, Ohio had a good assortment of stainless mixing bowls the last time I was there. They are on the web at Lehmans.com but I couldn't find the bowls on their webpage. They do have a mail order catalog available. If you need someone to go look I'm 5 miles away from the store.
DL
05-21-2005 17:49:47
Hey Gene,
No worrys... a friend of mine is a definite "guru" when it comes to stainless... has worked it for 40 years. Anyways, I've seen him take a piece he wants to polish and TIG all the little imperfections, grind, sand and then polish the steel... ends up looking like a MIRROR! I definitely would NOT use any type of alloy process (any of the solders) because TIGing w/stainless is cheap & easy & non-toxic... will make the bowl as good as new. TIG weld a pin hole in a mixing bowl.... $20.00... find someone to grind & polish the weld... $20.00... happy marriage... PRICELESS!!!
Regards, DL
Steve Crum
05-22-2005 05:53:36
 Re: Suggestions for stainless steel mending. in reply to DL, 05-21-2005 17:49:47
Several years ago I repaired the handles on several Revere ware cook pots a friend of my sister had sent to me. Within weeks I was getting 10 or more of these a week for repair, GEEZ people are rough on these! Word sure travels fast ! I tig welded the handles back on with full back gas and polishing.
This got so it was taking so much time away from the real shop production, that I had to put a stop to it. In order to charge a price that covered expenses and make a little, it cost less to replace the pot or pan with new.I still repair the occasional stainless piece for the local schools,churches etc.
Maybe I"ll do this after I retire!
mike brown
05-21-2005 15:20:10
Stainless tig welds nicely. Someone with experience should be able to do a nice job on a pin hole. Stainless can be soldered with 95/5 but you need to use cut acid flux.
