Tool Talk Discussion Forum
Trailer wiring impossibility
Slowpoke
05-20-2005 17:52:30
I had no left trailer brake light, so I removed the old 1157 lamp and the base pulled off as it came out. Easy fix. I put in another bulb and no light. Took it out and found one of the little solder blobs had fallen off. Easy fix. I put in a third and fourth bulb and still no brake light. I removed the bulb, put the meter probe on the terminal, get 12 volts at the thin, springy, brass bar. I wiggle the wire, press the terminal in and out with the probe, still 12volts. The bulb reads good on both filaments.
I put the bulb back while holding the probe on the terminal, the voltage goes to ZERO. Pull the bulb out, 12 volts again, either bulb. There's no corrosion. No longer an easy fix. What the h is wrong????
By the way, I'll be in the Catskill, NY area June 10, 11, & 12. Any one have an IHC 240 I can look at? I need to see the starter motor solenoid-to- armature connection.
Rod in Smiths Falls, ON,
05-20-2005 19:31:48
 Re: Trailer wiring impossibility in reply to Slowpoke, 05-20-2005 17:52:30
The quick and dirty solution? Run a ground wire from your tow vehicle straight to the offending tail light. I twisted the new wire around a screw inserted into the back of the metal light. It worked until the ground wire broke a year later.
Slowpoke
05-21-2005 11:20:59
 Re: Trailer wiring impossibility in reply to Rod in Smiths Falls, ON, , 05-20-2005 19:31:48
The lights are all plastic now.
Ralph - Ohio
05-20-2005 18:29:49
Regarding trailer light, my guess is a high resistance splice or connection somewhere in the circuit. When using the voltmeter very minimal current flow is required so a bad connection does not matter. But when bulb is plugged in much more current is required and the voltage is dropped across the bad connection. If your wiring includes some of those clamp-on splices that would be a good place to look.
Slowpoke
05-21-2005 11:49:25
 Re: Trailer wiring success in reply to Ralph - Ohio, 05-20-2005 18:29:49
You were exactly right about the clamp-on splice. Since the meter was not loading the circuit, I used a bulb and tested directly at the vehicle trailer receptical left brake pin. Still no light. I removed the left brake wire clamp-on connector and held the wires together with my fingers. Let there be light! It was a bad connection at the clamp-on. I soldered the connection and the brake lights work on both sides of the trailer.
MAC,IL
05-21-2005 14:10:31
 Re: Trailer wiring success in reply to Slowpoke, 05-21-2005 11:49:25
I sure never was a fan of the clipon connectors. solder is practically fool proof.
Coloken
05-20-2005 18:25:10
This is one of the things that happens with a volt meter that draws but a small current. You have a high resistance connection. It is good enought to "run" the volt meter, but not good enough to power the bulb. Usually the ground to frame.
Slowpoke
05-20-2005 23:46:09
 Re: Trailer wiring impossibility in reply to Coloken, 05-20-2005 18:25:10
I didn't think about the 20 meg resistance in the digital meter as part of the problem. The yellow left turn wire comes straight thru from the 6 terminal plug to the lamp contacts in the case. I had to tin the end of the wire at the plug because the wire size is too small for the terminal and tiny screw. The screw head bottomed out before bearing down good on the wire. The only place left for high resistance is the connection between the wire and the terminal in the case, and it's buried in plastic. It will probably melt if I try to solder another wire to the contact. What the heck, I might just do that. I think the original connection relies on pressure and not solder. Anything to make a product faster and cheaper on the assembly line. Looks like a new complete lamp holder may be in order. Thanks to all for the help.
thurlow
05-20-2005 19:08:18
First three things I look at when having problems with trailer lights/brakes..... ..1. ground 2. ground 3. ground
mike brown
05-21-2005 05:09:22
 Re: Trailer wiring impossibility in reply to thurlow, 05-20-2005 19:08:18
Solder the ends of the wires to the blubs!
We have four trailers at work that I have to keep working. After dealing with problems like yours I ripped out all the factory wiring which was grounded through the trailer frame and rewired grounding through the harness. I soldered and sealed all the splices and soldered the wire ends to the bulbs (before changing to sealed units) The blubs last a long time, it's usually the contacts that get cruddy and fail. I now use leds when I rewire. When we get a new trailer I insist on grounding through the harness though they still use those quick splicers.
mike brown
05-21-2005 08:06:31
 Re: Trailer wiring impossibility in reply to mike brown, 05-21-2005 05:09:22
Blubs????
Jet9N
05-21-2005 16:09:39
 Re: Trailer wiring impossibility in reply to mike brown, 05-21-2005 08:06:31
Maybe "blubs" last longer than "bulbs". Just couldn't resist being a smart a$$.
Jet
