Tool Talk Discussion Forum
Drill Bits
Jeff59
05-17-2005 16:32:08
I got a set of drill bits that have fractional sizes. But what are the numbered and lettered bits? What are they used for? Another question..are colbalt bits that much better than HSS for the money? Thanks
Jeff59
05-18-2005 17:09:22
 Re: Drill Bits in reply to Jeff59, 05-17-2005 16:32:08
Thanks everybody for the good help. Now I understand. I 'll print off the chart to keep with my tap set. Thank you. Jeff
TimV
05-18-2005 06:41:08
The most common use of number and letter drills is for making starter holes for taps. There are tons of online resources that give the proper drill size for various tapped holes. The link below is one of them, a quick Google of "tap size chart" or "drill size chart" will turn up lots more. Letter and number drills are very handy to have if you're doing anything more than basic homeowner shop work. One tip--buy a decent set of number and letter drills and then use them ONLY for what they need to be used for. Use your fractional drills to get close to the finished size, and then use the appropriate number or letter drill to finish. It sure stinks to need an exact size drill only to find out you broke that one drilling something that could have been done with a $2.00 hardware store drill bit.
KirkMn
05-18-2005 05:29:43
There is also different grades of HSS.
Cobalt - Best
M-7 - Better M-2 - good
M-1 - good
M-50 - cheapest
A good set of M-7 Heavy duty Jobber will work if you dont want to dump the bucks for a cobalt set.
A Heavy Duty Jobber will have what is called a split point.
A regular Jobber wont have the split point.
dr.sportster
05-17-2005 19:09:41
If you get a chart of tap drill sizes youll see the call for letter and number sizes.Another example would be you need a letter R for tapping an 1/8 inch pipe thread.For the hobbiest it may be cheapest to buy the ones you need then drill out a piece of wood placing the tap drill and the tap next to each other near the drill press.Just for maybe 1/4 nf with no.3 1/4-20 uses number seven etc.If I knew how to post a picture it would explain what Im trying to say but from 1/4 through 3/8 and eighth pipe tapered I have them in a piece of wood ready at the drill press in addition to the ones put away in the tap set.I think the quality of the tap is more important.TIN or cobalt coated is not that needed for this type use you just want the right size hole for the proper percentage of thread depth.I think sometimes there is no fractional size thats close enough to substitute for certain letter and numbers drills.
Slowpoke
05-19-2005 00:58:51
 Re: Drill Bits in reply to dr.sportster, 05-17-2005 19:09:41
Holders for taps and matching bits are available as are complete sets with the taps and bits in the holder. Makes it easy to find the correct bit and tap size for the job, since it's all together.
dr.sportster
05-19-2005 19:13:08
 Re: Drill Bits in reply to Slowpoke, 05-19-2005 00:58:51
Thats true but boards are free and Im cheap.
Slowpoke
05-20-2005 13:13:18
 Re: Drill Bits in reply to dr.sportster, 05-19-2005 19:13:08
So am I, so I only buy stuff at garage sales, thrift stores, or if it's on sale. Even if I don't need it now. Or if I think it's worth it to make life easier.
DL
05-17-2005 17:56:48
Hey Jeff,
The "numbered" sizes of drill bits correspond to "wire gauge" specs... a #12 drill bit is the same diameter as a 12 ga. wire... combined with the "letter" drills, these just give you more choices in hole sizes. This is important, for instance, when drilling a hole you intend to tap, or when drilling a clearance hole for a fastener. If memory serves, the correct hole size for tapping with a 3/8" - 16 tap is an "O" (letter O) drill. Using the correct drill ensures the proper strength/fit for threads or the proper clearance for fasteners. As far as the cobalt bits... depends on what you're doing with them... if they're just for use around the house, I wouldn't spend the extra money... if you're drilling stainless or certain alloys, they're worth any amount of money as far as I'm concerned! If you do opt for cobalt (or especially if you get solid carbide) drill bits, remember that as a metal gets harder, it also becomes more brittle... if you use these harder bits, be sure to use them in a drill press (or a mill). These harder bits break a bit more easily if used in a hand drill. Sorry this is so long, but hope it helps! Regards, DL
Regards, DL
