Tool Talk Discussion Forum
Which Grease for General Lube?
pbutler
05-17-2005 16:07:47
I purchase a Lincoln Electric grease gun last year-and love it. Now I have the one old manual just for lubing corn head with high pressure stuff but am wondering what I should be using for everything else.
Mostly just wagon axles, general trator lube points, and everything but the cornhead on the combine.
Last year I just used the Harvest King generic stuff from Farm and Fleet but with a nicer/larger combine I want to be sure and take care of things as best as possible to prevent breakdowns.
There are so many choices, moly, synthetic, lithium, etc.
Any advice?
Eddie in MI
05-20-2005 19:25:34
 Re: Which Grease for General Lube? in reply to pbutler, 05-17-2005 16:07:47
I use Mobil 1. I like it 'cause it's red, lol!
Leland
05-19-2005 19:49:43
I starting using tubes of marine wheel bearing grease for every thing and it is a better grease as far as I am concerned.
farmweld
05-18-2005 08:27:06
my local C&E carries 5 gallon buckets of lithium based grease, and i just buy these about once a year, and i never run out of grease. main thing is to not mix types of grease, though. few weeks back, there was a discussion on here about mixing grease. try lookin in the archives.
lucasss
05-18-2005 04:53:50
for sealed ball bearings a grease suitable for automotive wheel brgs is best . for bushings,unsealedbrgs ,tie rods , the cheep tsc grease is ok.think about it... lucas
MAC,IL
05-18-2005 04:46:21
Heck I just get "grease" from the local TSC. Main thing is keep the stuff greased.
dr.sportster
05-17-2005 18:49:54
Every one you named sounds good to me.I actually bought a good supply or several cases awhile back at a machine shop supply store closing.I guess its just brown grease.If its not alot more money a moly based would seem a good choice.Not being an oil or grease expert I often just use what the manufacturer calls for.Im not sure if lithium is ok for all applications or not.Any grease is better than no lube.So in closing I know nothing really helpful about grease.Why am I still typing this...
napaguy
05-17-2005 19:59:25
 Re: Which Grease for General Lube? in reply to dr.sportster, 05-17-2005 18:49:54
i have to agree with dr. sportster...we keep at least 12 different kinds of grease (in tubes) and i doubt that one does a better job of lubricating than the others. only exception i can think of is waterproof grease for boat trailer bearings.
