Tool Talk Discussion Forum
help with loading pics on forum
pperry
05-16-2005 19:04:16
how do i load a pic with my message on the discussion forms..thanks perry in mi
Rod (NH)
05-17-2005 08:44:54
 Re: help with loading pics on forum in reply to pperry, 05-16-2005 19:04:16
third party image
Hi,
I see no one else has taken the time to help you out so here it is:
First, your picture has to be located on an internet server computer somewhere, for instance in one of the image galleries at this site.
There are a couple of ways to make the picture show up in your post. One way is to insert the appropriate html coding in your message. The other, easier, way is to fill in the proper information in the correct line below the post box. The proper information to fill in is the URL location of the picture. The correct line below the post box is called the "Optional Image URL" block.
For instance, here's the URL information for the latest tractor picture in the Tractor Photo image gallery:
Link
You get this information by right-clicking on the picture and selecting "properties" from the list that results. In the dialog box that pops up, right click on the line titled "address (URL)" and click on "select all" in the list that comes up. This will highlight (select) the picture address information. After this is highlighted, right-click on it again and select "copy". This will copy the picture address information to your computer's clipboard.
Go to your post box and type your message. Before you submit your message, insert your cursor in the "Optional Image URL" block beneath the post box. Right-click in that block and select "paste" from the list that comes up. This will put the picture location in the block and you can continue with submitting your message to one of the forums.
At the top of this message is an example of my doing just that in this post, using Mark's tractor photo that he had uploaded to the gallery.
third party image Rod
Leroy
05-18-2005 02:58:53
 Re: help with loading pics on forum in reply to Rod (NH), 05-17-2005 08:44:54
How do you get it from the camara to the photo page? Direct link with a digital camara? Scanner with a 35MM camara? Out of a book?
Rod (NH)
05-18-2005 05:44:12
 Re: help with loading pics on forum in reply to Leroy, 05-18-2005 02:58:53
Hi Leroy,
First off you will need to have the picture located somewhere on your computer. It should be in .jpg image format. You get it from your camera to your computer using the instructions/software that came with your camera.
Once you have a .jpg image on your computer hard drive you should check the image size in pixels. You should be able to use whatever image software that came with your camera to do this. Ideally, for web and forum use, the size should not be greater than 640x480 pixels. You may have to use image editing software to reduce the size. I think this site automatically reduces the size but others do not. Make sure you remember the exact location and name of your picture. Only use standard letters or numbers in the name. Do not use spaces or "special" characters. Write down the full path to the picture on your hard drive - you'll need it when you upload the picture to the image galleries on this site. An example might be: C:\My Documents\My Pictures\AllisB.jpg.
Go to one of the image galleries and click on "add your photo" at the top of the list of available photos. In the dialog box that comes up, fill in the information as necessary and click on "next step". In the next dialog box, click on "browse". In the window that pops up, navigate to the location on your computer where your picture is located. Select your picture and click on "open" or something similar to insert the picture location on your hard drive into the space provided. Then click "submit" and your picture will upload to the image gallery on this site. You may not get an indication that the upload is completed, so give it plenty of time.
pperry
05-17-2005 19:13:47
third party image
thanks for the reply, ill see if this works
pperry
05-17-2005 19:23:42
 Re: help with loading pics on forum in reply to pperry, 05-17-2005 19:13:47
third party image
the pics keep coming up as a red X
Rod (NH)
05-17-2005 20:16:51
 Re: help with loading pics on forum in reply to pperry, 05-17-2005 19:23:42
Steve is correct in that you are getting way too much "stuff" in the URL address. It looks like you are right-clicking somewhere else on the page rather than on the picture itself and are therefore getting the entire page address. This will not show up as an image and you will get that red X. Make sure your cursor arrow is directly over the actual picture before you do the right-click.
Steve (Magnolia, TX)
05-17-2005 19:52:10
OK.
What appears to be happening is that you're copying the contents of the "Address" line of your web browser?
If you're wanting to insert a photo from this website (or any other website, for that matter) then you'll need to right click on the actual photo, then left click on Properties. Look for the "Address: (URL)" (it should look something like;>Link
Now you're ready to put it in your post. Here's a basic HTML primer, that I kinda like, but... here's the basic structure required to post a photo;
1. Open your HTML command with the "<" symbol (remove the quotes)
2. Specify an image with "IMG" and follow this with a blank space.
3. Specify the source of the image with "SRC=http://www.tractorshed.com/gallery/tphotos/a27750.jpg", where everything after the "=" is the URL of the photo that you want to insert
4. Close your HTML command with the ">" symbol
An important note is that the photo that you're linking to MUST be on avialable on the internet (i.e. NOT in your "My Pictures" folder, on your computer). Personally (and this is not an advertisement) I like PhotoBucket, partly because each photo includes (not only the 'basic' URL, but) the entire HTML 'tag' required to insert the picture.
So...
Here's what you would type (all on one line) to insert the picture, below;
SRC=http://www.tractorshed.com/gallery/tphotos/a27750.jpgAnd here's how it looks, inserted;
HTH
Steve
pperry
05-18-2005 14:00:11
 Re: no propertys in reply to Steve (Magnolia, TX), 05-17-2005 19:52:10
when i right click on the picture i dont see propertys. it say add book mark at the bottom of the list
05-19-2005 06:15:07
 Re: no propertys in reply to pperry , 05-18-2005 14:00:11
It's been so long since I've done anything with Windows 98 that I don't know as I'll be able to help you.
Did you give PhotoBucket (or another similar website) a try? I know (for a fact) that any photo that you upload there automatically displays the full HTML tag for you....
HTH
Steve
thurlow
05-18-2005 14:19:48
What happens when you right click somewhere else? When I right click ANYWHERE (PC running Windows 98), I get a column with ; "Back", "Forward", "Save background as", "Set background as", "Select all", "Add to favorites", etc; last thing in column is "Properties"..... ...
pperry
05-18-2005 19:08:50
 Re: no propertys in reply to thurlow, 05-18-2005 14:19:48
my last thing on the list is add book mark. only on the picture. if i move the curser off the pic and onto blank part of page i can get propertys to show up. but not on pic. im running win98, sbc global internet.
AZ Jack
05-17-2005 21:51:58
 Re: help with loading pics on forum in reply to Steve (Magnolia, TX), 05-17-2005 19:52:10
third party image
I am going to try this myself and see if I can get it to work. Jack
