How to build a rotary phase converter ?
al
01-10-2001 18:15:35
Anyone have plans on building a rotary phase converter.Around a 10 hp size.
al
Chuck Smith
08-20-2002 18:02:09
 Re: How to build a rotary phase converter ? in reply to al, 01-10-2001 18:15:35
Would like to obtain a set of prints
Chuck Smith
08-20-2002 18:02:08
Tom R
01-11-2001 09:55:16
Al:
Here is another web site you may want to check out. Tom R
"http://members.home.net/rdoctors/ph-conv.html"
Big Jake
01-11-2001 08:35:04
www.metalwebnews.com/howto/ph-conv/ph-conv.html
Link
Link
ltf in nc
01-11-2001 08:30:00
I will send a drawing to your e mail if you want it. It takes a while to download.
Dave53
08-06-2004 17:57:10
 Re: Re: How to build a rotary phase converter ? in reply to ltf in nc, 01-11-2001 08:30:00
I would really appreciate a copy of the drawing as well.
Thanks
Dave
Larry Willis
06-06-2002 20:25:55
Would it be possible for you to email me your plans on building a phase converter? I have a metal shear that is three phase and would like to run it as single. Your help would be greatly appreciated. Thanks, Larry
al Thanks LTF I got it
01-11-2001 18:50:02
thanks,al
tony
07-10-2002 16:08:11
 Re: Re: Re: How to build a rotary phase converter ? in reply to al Thanks LTF I got it, 01-11-2001 18:50:02
please send me plans to build a phase converter
thanks tony
al LTF yes I would appreciate it.
01-11-2001 15:04:35
LTF just click on my name in blue for the -mail address or
[email protected].
Thanks al
jeb
01-11-2001 13:13:50
I would appreciate your hand made drawing and will use it at my own risk. It's probably simpler than most expanations that I've seen.
[email protected]
Mike Danford
01-11-2001 09:05:17
I'd love to have one, too, if you don't mind. I've been carrying around a 1 HP and 7.5 HP three phase motors for seven years waiting for the "know how" to make rotary phase converters out of them. That's one project I'd love to dust off and finish!
Mike Danford
Chickamauga, GA
ltf in nc
01-11-2001 10:51:07
 Re: Re: Re: How to build a rotary phase converter ? in reply to Mike Danford, 01-11-2001 09:05:17
Not a problem but you will have to post an e mail address. This drawing is a freehand effort but it definitely works. You will be using this at your own risk.
ltf in nc
01-11-2001 10:50:29
Mike Danford
01-11-2001 19:03:24
 Re: Re: Re: Re: How to build a rotary phase converter ? in reply to ltf in nc, 01-11-2001 10:50:29
Thanks! Got it just fine and will get busy this week, I can just see the freed up shelf space now... No worries, all liability assumed herewith (or whatever).
Mike
Ray,In
01-10-2001 20:53:56
Plans are on the web, can't remember the site. I found it w/search engine. appeared quite professional.
Ray,In
01-13-2001 20:48:00
 Re: Re: How to build a rotary phase converter ? in reply to Ray,In, 01-10-2001 20:53:56
I found it: Link Shows both static and rotary schematics.
Dick L
01-10-2001 20:38:11
Purdy simple. You need a 10 HP or larger 3 phase motor. Hook the two hot single phase wires to two of the proper sets of the three phase leads that you would connect to wire the motor if you were going to run the motor. Belt a single phase motor to the 3 phase motor and start the 3 phase motor rotating at full speed with those two single phase wires hot. You can then pick up your third phase from the third connection of the spinning 3 phase motor. After the motor is up to speed you can unbelt the starting single phase motor and the three phase motor will continue to run and generate the third phase
VaTom
01-11-2001 07:55:30
 Re: Re: How to build a rotary phase converter ? in reply to Dick L, 01-10-2001 20:38:11
Or do what I did which was to put a chain drive on the dummy motor shaft and kick it with my foot to get it spinning. Then turn the switch on to feed single phase to the dummy motor. I've been running industrial machinery that way for years with no ill effect other than the elec. bill. Of course you don't get full power from your tool. Far as I can tell, the capacitors in a commercial rotary converter only are used to start the dummy motor. I'd just as soon kick-start it as pay the $60 for the capacitors. A true 3 phase would be nice but I don't want to set up a shop where it's available.
Dick L
01-11-2001 13:45:13
 Re: Re: Re: How to build a rotary phase converter ? in reply to VaTom, 01-11-2001 07:55:30
Yup, I see they all wants something fancy. I worked with a guy that had a ten man tool shop run on what I discribed for many years. He was out in the country where 3 phase couldn't be had. He was useing a 75 horse motor to generate the third phase. He had to use two horse motors rather than one horse motors on his mills.
Elmer Becker
12-26-2003 18:19:04
 Re: Re: Re: Re: How to build a rotary phase conver in reply to Dick L, 01-11-2001 13:45:13
Hi, Do you use 110 volts in each of the two wires that goes to the phase converter motor (3 phase motor) for leg 1 and 2? If these two wires are to be 220 volts, how do you wire them from a control box to the 3 phase motor?
