Tool Talk Discussion Forum
Trailer Hitch
luckydog
05-15-2005 04:30:14
Just purchased a goose-neck trailer and have a ball plate made that I am going to put in. Question, how far is the ball to be in front of the rear axel? Thanks luckydog
Kevin (FL)
05-18-2005 07:32:12
 Re: Trailer Hitch in reply to luckydog, 05-15-2005 04:30:14
Luckydog,
We installed a hidden hitch in our F350 bed and the ball ends up right over or maybe an inch or so forward of the axle. The hitch is heavily built and it bolts to the frame with heavy plates--many connection points to spread the load. It's rated at 30,000#'s. On yours I would make sure you have several brackets underneath to spread the load out too. Also, be wary of installing the ball too far forward, because your trailer will track over too far in turns. In other words, if your trailer tracks over to either side in turns, you'll be taking out mailboxes, fence posts, street signs, telephone poles, etc. while making hard turns.That makes a lot of difference if your trailer is a long one like the one we pull--it's 36' long, not including the frame that runs over to the truck.
captaink
05-17-2005 11:27:20
I place mine as far ahead as I can and still get backed under the trailer with the end-gate down. I generally try for 7 to 8 inches in front of the rear axle. This does two things. One it puts more weight on the steering axle, second it moves the sideways pull between the axles, not just over one of them. These two factors make the vehicle a LOT more stable. There is a limit as to how far ahead you can move it, and this is limited by the length of the trailer hitch itself. I have even put hitches in short box pickups this far ahead. As long as the trailer hitch is designed so that it doesn�t interfere with the cab when turning, it works great.
My experience was that I had a gooseneck on a � ton two wheel drive pickup. The ball was about 8 inches in front of the rear axel and I pulled a 6X20 livestock trailer with 10 cows in it with no handling problems what so ever. I then bought a heavy duty � ton 4-wheel drive pickup (both were just traditional cab, 8ft box) that was already set up with a ball only 2 inches ahead of the rear axle. It handled the same trailer and similar loads terrible. I changed the ball setup to a hide-a-ball and moved it ahead to 8 inches in front. After that it handled trailers like a dream.
I now have a heavy duty 4X4 diesel extended cab 8� box that I have set up the same way. I pull a 24 ft gooseneck flatbed with a 13,000 # backhoe on it, a gooseneck hopper bottom trailer that will hold 330 bushels of grain, and still have the 6X 20 livestock trailer. I never, ever have a handling problem even when plowing through snow drifts in the winter.
RustyFarmall
05-15-2005 12:56:25
Your hitch ball needs to be attached directly to the truck frame. If you simply attach it to a plate that is then bolted to the sheetmetal bed you run the very definate risk of tearing out the sheetmetal. Older trucks had much heavier guage metal in the beds, the newer trucks are quite thin and very flimsy.
In any event, the ball needs to located anywhere from 4 inches to 6 inches AHEAD of the rear axle.
luckydog
05-15-2005 17:57:06
 Re: Trailer Hitch in reply to RustyFarmall, 05-15-2005 12:56:25
I Bolted the plate threw the bed and to the frame. Problem was I had forgoten what the distance was. Thanks for all comments. luckydog
old
05-15-2005 07:33:28
All the ones I have seen and or owned, where placed right over the rear end, or just a little forward. The truck I have right now has it about 4 inch forward of the rear end, and my 5th wheel hitch is right over the rear end.
