Tool Talk Discussion Forum
Weedeater troubleshooting
Roger9
05-13-2005 17:53:23
I have a fairly new Echo weedeater that has recently been losing power. Have replaced air filter, fuel filter, spark plug, new gas, and have inspected spark arrester. Can"t think of what else to do besides tear the thing apart hoping to find something. Any ideas?
Lucky4800
10-05-2006 20:04:03
 Re: Weedeater Blower Vac in reply to Roger9, 05-13-2005 17:53:23
When i prime and start my blower vac it leaks fuel. I once primes it 6 to eight times. think this is what the manuel said. Now i have tried to just prime it one and it starts just fine but still leaks oily fuel on my concrete. Can someone tell me what to do?
Eric Tobosa
08-11-2006 23:43:32
 Re: Weedeater troubleshooting in reply to Roger9, 05-13-2005 17:53:23
I just bought a second hand Echo weedeater. The problem is it won't start. When I bought it it started after 15 times pulling the cord. I changed the filter and fuel filter. The spark plug looks ok. It does have gas. What could be the problem? Thank you!
roger9
05-14-2005 22:06:49
Hi. I am the one who posed the original weedeater question. This is the first time I have ever used this discussion board (or any other for that matter), so I am fascinated at how it works. I'm not sure how to go about saying "Thank You", so I will just mention it here and hope the appropriate people read it. My weedeater is now running great!
Exactly as diagnosed: carbon build up in the exhaust port. And you are also right, ECHOMASTERSERVICETECH, in that I don't always run it at full throttle. Now I can be more aware of the situation. Once again, thanks to all who contributed to my dilema.
T_Bone
05-15-2005 02:06:48
 Re: Weedeater troubleshooting in reply to roger9, 05-14-2005 22:06:49
Hi Roger, Welcome To The Forums :)
You will not find another website forum with the amount of knowledge that is here on this forum. I don't think in 10yrs that I've seen too many topics that go unanswered and I learn something new every day.
What a great group of guys and gals.
T_Bone
ken adair
07-09-2006 11:52:56
 Re: Weedeater troubleshooting in reply to T_Bone, 05-15-2005 02:06:48
my weedeater featherlite ran great last week. know it don't start at all. please help. pissed off.
05-14-2005 03:25:29
WORKING FOR THE TOP ECHO DEALER IN THE STATE OF MO. THIS WAS A COMMON PROBLEM SEEN, THE ABOVE LISTED SOLUTIONS ARE VERY ACCURATE. I WOULD ALSO SUGGEST REMOVING THE MUFFLER FROM THE UNIT ANDINSPECTING EXHAUST PORTS. IF EXCESS CARBON IS FOUND IN PORT, BRING PISTON JUST PAST THE BLOCKAGE AND USING A WOODEN DOWEL CLEAN CARBON OUT,THEN BLOW CYLINDER OUT WITH COMPRESSED AIR, WEAR EYE PROTECTION. THE LEADING CAUSE FOR THIS IS INSUFFICIENT OPERATING TEMPERATURE, THAT IS MOST PEOPLE WHEN OPERATING UNITS SUCH AS SRM2100 SELDOM BRING MACHINE TO FULL HIGH RPM. THE ENGINE WAS DESIGNED TO RUN W.O.T. WIDE OPEN THROTTLE. ALSO CONSIDER USING A REPUTABLE TWO CYCLE MIX IT DOES MAKE A DIFFERENCE. FINALLY I DO NOT RECOMMEND THROWING AWAY YOUR SPARK ARRESTING SCREEN IT CAN BE CLEANED EASILY BY HEATING WITH A PROPANE TORCH. SECURE WITH A PAIR OF PLIERS AND HEAT TO A CHERRY RED, BLOW OUT PARTICLES WITH COMPRESSED AIR AND IT WILL BE AS GOOD AS NEW, IT DOES HAVE A PURPOSE AND FOR TWO OF MY CUSTOMERS WOULD HAVE SAVED A VISIT BY FIRE DEPARTMENT
R K TEK
05-14-2005 11:21:49
 Re: Weedeater troubleshooting in reply to ECHOMASTERSERVICETECH, 05-14-2005 03:25:29
STOP SHOUTING!!!!! !!!!! !!!!! !!!!! !!!!!
Dave Sherburne,NY
05-14-2005 15:41:26
 Re: Weedeater troubleshooting in reply to R K TEK, 05-14-2005 11:21:49
Thanks for the rain.
John Van Valkenburgh
05-13-2005 23:54:26
Take a real good look at the exhaust hole in the muffler. Here in NC we get these little "mud dauber" wasps that build in anything thats even semi-round. I've had a couple of gas powered string trimmers that they've build nests in the muffler.
John
Tim Talafuse
06-01-2005 18:06:56
 Re: Weedeater troubleshooting in reply to John Van Valkenburgh, 05-13-2005 23:54:26
All,
New twist. The weedeater will start if I hold the gas wide open and run up to full speed. However, as soon as I let off the gas it dies. I have tried changing the plug, various filters, adjusting the carborator, and all the other things suggested, but no luck. Any thoughts or ideas?
mud
05-15-2005 09:09:04
 Re: Weedeater troubleshooting - makes me think! in reply to John Van Valkenburgh, 05-13-2005 23:54:26
Mud Daubers-- neighbors tractor was losing hydraulics. After some effort they come to find a daubers nest in the hydraulic system vent.
Engineer20
05-13-2005 19:18:01
I took the muffler off and cleaned everything. Threw the spark arrester away. Never had a problem since.
clarkdavidson
05-20-2005 13:36:24
 Re: Weedeater troubleshooting in reply to Engineer20, 05-13-2005 19:18:01
hellomydadishavingtroubleswithhisweed
eaterhecannotfigureouttheproblemwithit
itwantstoraceonhighwhengoestouseitit
isnotaverygoodenginecausehehashadthethingawhile
anditseemstheenginejustdoesnotwanttoworkright
itseemslikeeverythinghebuysorgetstheenginesjust
donotwanttoworkproperlyhehastriedeveythingandhe
isgettingfedupwithstuffbreakingdownonhimsocould
youpleasehelphimoutbycallinghimathometohelp
figureoutwhatishappeningtohisgaspoweredtoolsor
stuffthatheheusestocareofhisyardmostlythatdang
weedeateritisapainintheasstofixwearehvingatuff
timewiththeweedeateranditisheavytoorealheavyto
carryaroundwhenitiswarmoutisweatalottomuch
Frank M.
05-20-2005 16:16:08
 Re: Weedeater troubleshooting in reply to clarkdavidson, 05-20-2005 13:36:24
Mustbehavingtroublewithyourkeyboardtoo
op
06-05-2005 09:20:50
 Weedeater blower troubleshooting in reply to Frank M., 05-20-2005 16:16:08
My blower works great for about 10 minutes then stops completely and won't restart. During the 10 minutes it has great power. I am guessing it may be the fuel filter. I have already drained the tank and refilled with a fresh mix, but the same situtation happened...any ideas?
Ralph - Ohio
05-13-2005 18:26:12
I'm not familiar with Echo but on the Weedeater brand engines the muffler would fill up with carbon restricting exhaust flow and reducing power.
