Tool Talk Discussion Forum
Sorry, pics broken..
Truck
05-13-2005 14:25:51
I can't do pictures right now as the computer floppy is not cooperating...BUt it is basically a 4 inch long by 2 inch high area with a horizontal line where the antifreeze has been seeping out while the engine is running. It is in a non structureal part of the water jacket on the vertical side of the block. It looks as if someone wasn't too good at brazing or cleaning the surface before they brazed, and they attempted to coat the whole area with braze. They didn't drill the ends of the crack as far as I can tell. All the brrass makes welding it a tough job, and it would be a lot to pin as well. It had been used this way for the last ten years, so I am hoping I can clean the surface with grinding or spot blasting with a vac sandblaster, and that applying a thin even layer of Devcon will fix it for a good long time.
Redmud
05-13-2005 15:34:59
 Re: Sorry, pics broken.. in reply to Truck, 05-13-2005 14:25:51
Truck, is the crack on a flat surface of the block? or some what flat? and do you have about 1/2 inch above and below, and at each end of the crack?
Truck
05-14-2005 04:41:27
 Re: Sorry, pics broken.. in reply to Redmud, 05-13-2005 15:34:59
Relatively flat, there are some 1/16th by about an inch wide ribs in the block it goes thru.
