Tool Talk Discussion Forum
Rotten egg smell from water heater
MarkB_MI
05-13-2005 03:58:27
I discovered something that some of you might find useful. Last year I replaced my water heater with a new GE heater, made by Rheem. Since then, the hot water has smelled horrible. I tried shocking the well with Clorox, I replaced the water softener (which was already shot); nothing helped. The smell was mostly a nuisance for me, but women have some peculiar ideas about how things should or shouldn't smell.
Finally I did a little research. It turns out that Rheem uses magnesium anodes, which are known to cause this problem. (Rheem's website claims that this isn't so, but I'm afraid they're wrong.) I replaced the original magnesium anode with an aluminum anode, and guess what: problem solved.
When I talked to the guys at the plumbing supply house, they knew all about this problem, so maybe it's common knowledge. I sure hadn't heard about it.
chris in md
05-14-2005 15:18:28
 Re: Rotten egg smell from water heater in reply to MarkB_MI, 05-13-2005 03:58:27
Regarding the problems getting the anode rod out, if you have to cut it to get it out, they make anode rods in 'links' that looks like a string of sausages, so you can feed it in the water heater. Ask at your plumbing supply if you need one. I'm lucky to have a great old mom + pop plumbing store right on main street mt. Airy, they have taught me most everything I know about plumbing.
Good luck
-Chris
john in Ct
05-13-2005 18:30:01
The exact thing happened to us a few years ago. Put a brand new heater in a house, little while later rotten egg smell. The #$$%%^^ plumbing supply company said that it was a rod and gave us one. No head room so had to take the heater out, flip it on it's side to install the rod. Rotten eggs again, Gave us another rod to put in, same thing. They were blaming the city water, the way we installed it, the man in the moon, etc. Finally, they took it back like they were doing the biggest favor in the world. Went to Home Depot, got a new heater and NO Problems at all!!!!! You need a new water heater.
MarkB_MI
05-13-2005 19:33:42
 Re: Rotten egg smell from water heater in reply to john in Ct, 05-13-2005 18:30:01
John,
I understand this problem depends a lot on your particular water. So what worked for me might not work for you.
However:
If you were replacing the anode with the same kind, it probably wouldn't help.
If you were replacing the anode without sterilizing the water heater, it probably wouldn't help, either. The smell is created by bacteria; apparently particular combinations of water chemistry and anode metal encourage bacterial growth.
Strangely enough I didn't have any trouble until I installed a new Home Depot (GE/Rheem) water heater, while you had no problems with the same brand heater. Go figure.
Weirsdale George
05-13-2005 15:15:20
Mark, If you are right, I would kiss you if you were of the right gender! I have identical water heaters (brand, size and age) in my shop and home and for some reason, the shop water heater has always had a real strong rotten egg smell -- I guess it is because a lot less hot water goes through that one than the house water heater.
Now, how do I remove the anode?
LocoLobo
06-02-2005 07:52:31
 Re: Rotten egg smell from water heater in reply to Weirsdale George, 05-13-2005 15:15:20
The anobe rod is a sacrifice to water attacking the least resistant metal in the heater. It is designed to be corroded. This protects the tank and gives the heater a longer life span. There is seven types of water across the US, I believe. The wrong anode can cause the rotten egg smell or " gassing" in the distribution system piping. Whereas opening a faucet there is a puff of gas in the water flow.Normally the mfg will insure the correct rod is installed for the area the heater is being shipped. Some rods are stamped on the cap with an identifing mark.
MarkB_MI
05-13-2005 19:24:39
George,
Start by shutting off the water to the heater and draining a few gallons out of the tank.
The anode is directly behind the chimney. (I assume you have a gas heater.) It is attached to a 3/4 inch pipe plug in the top of the heater. You'll need a 1-1/16 inch socket to take it out. It's pretty darn tight; I had to put a piece of pipe on my 1/2 inch drive breaker bar to bust mine loose.
Once you have the pipe plug loose, you can pull it straight out the top. If you have enough headroom, that is. If you can't pull it all the way out, you'll have to cut it. Clamp the anode with a pair of Vise Grips so it can't fall inside, then cut the anode in two with a hacksaw. Try not to get chips in the water heater. (Once you have it partially cut through you should be able to break it. It has an iron wire in the middle that you'll have to work a bit to break.) You should then be able to pull the bottom half of the anode out.
When you get the replacement anode, make sure that it's aluminum, not magnesium. If you had to cut the old anode to get it out, you may have to cut the new one as well.
Before you install the new anode, dump a cup of Clorox in the tank to kill any bacteria. Let it sit for half an hour, then drain any sediment out of the water heater. Then run all your hot water taps until the Clorox smell goes away.
Good luck, I hope it works for you.
msb
05-13-2005 19:20:19
The rod is on top of the heater.Looks like a pipe plug.It may even be marked "anode".Remove it and replace it with an ordinary pipe plug of the proper size.The rod will go almost all the way down the heater in length.
j-tex
05-13-2005 06:13:21
i went through the same problem about 6mo ago.
changed the rod and flushed the tank, problem solved
