Tool Talk Discussion Forum
Drill chuch removal
Jay87T
05-12-2005 06:21:54
hey guys, I have a Dewalt hammer drill and the chuck does not hold the bit very well, it is also very tight when trying to adjust it to the bit. I have tried to oil it and WD-40 it but its still tight. I would like to replace it, question is how do I get this damn thing off?
Mike Burdick
05-13-2005 19:50:57
 Re: Drill chuch removal in reply to Jay87T, 05-12-2005 06:21:54
Below is what I copied from Dewalt"s web site about chuck removal. Since I don"t know your exact model, this may or may not apply. If I were you, I"d give them a call (they have a toll free number) and ask.
From Dewalt"s web site:
Please follow the instructions below to remove a chuck:
Most reversing drills have a left hand threaded screw inside the chuck.If the unit has the screw follow all 3 steps below. If the unit does not have the screw use only step 3.
1.) Place chuck key into one of the holes of the chuck (for keyed chucks only) on the right side. With the chuck facing toward you, strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into front of chuck between jaws to engage screw head. Remove screw by turning clockwise(left-hand screw).
3.) Place key in chuck again. With the chuck facing toward you place the key on the left side of the chuck. Using a wooden mallet or similar object, strike key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
Instructions for removing a keyless chuck:
Remove left hand threaded screw if necessary(steps 1& 2).
Insert a 1/4" hex key or larger short end into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard thread.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck.
Boog
05-13-2005 05:07:02
I recently removed a Craftsman chuck and it was indeed a Left Hand Thread. I had to get a BIG cross tip screwdriver and really twist that muther.
Big Jim
05-13-2005 00:30:24
If you use it much as a hammer-drill be sure you clean out the chuch frequently. Hammer-drill dust can really screw things up pretty quickly
Ryan - WI
05-12-2005 14:49:19
Like was previously posted, the screw inside is a left hand thread. Take that out by hand, then chuck a large allen wrench in the drill, put the end of the allen in a vise and turn off the chuck using reverse in the drill.
chuckinnc
05-12-2005 10:17:18
The screw is a left hand thread so the chuck wont
back off in reverse so turn it clockwise to loosen
then then chuck may be on to tight to unscrew, i
ususlly put the chuck key in the chuck and tap it
with a hammer (counter clockwise) to unscrew the
drill chuck.
MAC,IL
05-12-2005 10:12:59
I have diamantled/repaired chucks that were rough like that one. If it has a center screw however it may be LHT.
Ron from IL
05-12-2005 06:55:25
Jay,
Most chucks are held in place by a screw. Open the chuck all the way and look inside. You should see a hardened cap screw (allen head). Remove it and you should be able to unscrew the chuck.
Good Luck!
Ron
