Tool Talk Discussion Forum
Torch Popping
John Van Valken
05-11-2005 15:53:03
I was trying to use the rosebud tip on my Oxy-Acy torch today and it kept blowing out with a loud "Snap". I run about 9 psi of Acyeletyne and 30 psi of Oxygen. Typically I get about a 12 inch Acyeletyne flame started and then slowly build up the Oxygen until I get a nice blue crown. It will hold this for about 10-15 seconds and then "snap" it blows out.
I'm familiar with this sort of problem on my cutting torch if I set the flame for too much oxygen or if I smother the flame by getting it too close to the work (i.e. too much back pressure), but the rosebud was giving me fits before I even put it close to the work.
Too much Oxygen pressure?
Thanks,
John
Farmall Teen
05-12-2005 16:49:16
 Re: Torch Popping in reply to John Van Valkenburgh, 05-11-2005 15:53:03
The tip could be getting to hot. My to cents.
T_Bone
05-12-2005 03:44:41
Hi John,
Well I have to agree with alot thats been said. A 12" flame of acetylene on a small cylinder is large draw for a small cylinder size.
Try turning down the acetylene flow rate and see if it flames out. If it does then it's most likely a air leak at the mixing body connection "O" rings. Could also be a scored mixing body bore.
T_Bone
flame
05-11-2005 18:47:08
Jack up the act. pressure but do not exceed 15 psi.
Old Peddler
05-11-2005 17:35:46
It sounds like you are getting acetone into your acety/oxy mix and that is causing the popping.
Basically, an acetylene cylinder will only release 1/7 of it's capacity per hour. For example a full 100 cu ft cylinder will release a little over 14 cu ft per hour. Any more than that and you start getting acetone which is the liquid that acetylene gas is stored in, inside the cylinder.
If you are using a small rosebud it may be best to get a full cylinder or one that has more cubic feet.
The other option is to manifold two or three acetylene cylinders together, expensive though.
You can check the paperwork that came with your rosebud to find out for sure what is recomended. Let us know what you find out.
Good luck!
thurlow
05-11-2005 16:50:03
My experience has been that the tip is not properly seated..... ..... ....
welder man
05-11-2005 16:13:17
to much oxygen ! All torches should be ran with a 50/50 mix.
gahorn
05-11-2005 23:00:01
 Re: Torch Popping in reply to welder man, 05-11-2005 16:13:17
Welder man...that is incorrect and unsafe advice. Never run more than 15 psi on acetylene and 7 is about right for most purposes.
dr.sportster
05-15-2005 12:28:29
 Re: Torch Popping in reply to gahorn, 05-11-2005 23:00:01
He said a fifty fifty mix not 50psi.Use 6 oxy/6 acet.All rosebuds pop till warmed a little.If its new its not dirty.Play the knobs till it stops then start the job.It will work.
Joe(TX)
05-12-2005 09:39:44
Waht was suggested is not unsafe or incorrect. Welder man did not say to increase the acetylene. He said it was too much oxygen, which it is. The tip probable needs to be cleaned.
bang
05-11-2005 19:12:18
the popping makes a nice bang into the phone when the soliciters call the shop. i dont get to many call backs
05-11-2005 19:53:06
 Re: Torch Popping in reply to bang, 05-11-2005 19:12:18
I recon you would not get any callbacks at that. Unfortunately I live on a horse farm and the residents don't much care for it either.
