Tool Talk Discussion Forum
air compresser bypass valve
oliverdave
05-11-2005 06:34:27
I have a old air compresser I want to put a gas engine on, and i'm looking for a bypass valve so it do's not keep putting air the tank.Any one know were I can get one?
XXX
05-11-2005 19:05:32
 Re: air compresser bypass valve in reply to oliverdave, 05-11-2005 06:34:27
You need one of these valves which will vent the output of the compressor to atmosphere once it reaches cut-out. A secondary port on the valve body sends a signal to a throttle control to slow down the engine when not pumping air into the tank. A simple air cylinder mounted on an angle-iron bracket, attached to the throttle works nicely.
jeffcat
05-11-2005 18:49:03
If you get a compressor set up to run with an engine you have the one way valve and the pump needs unloader heads. You need a different type of pump to do it right. Sorry. Jeffcat
Bob
05-11-2005 08:15:44
You want an "unloader valve".
Grainger is one source.
Fred OH
05-11-2005 06:49:42
OD...my portable has a safety that lifts at around a hundred and some pounds and it lets air pressure go to a small piston that brings the throttle back to idle and at the same time lifts the reed valves (or something similar) so it"s free wheeling when it starts pumping again. The only way that I can see that you can do yours is to have a safety valve lift when it gets up to pressure and stay lifted till it needs to pump more. Does that make any sense to you? Fred OH
oliverdave
05-12-2005 07:10:21
 Re: air compresser bypass valve in reply to Fred OH, 05-11-2005 06:49:42
I found that napa can get the unloader assembly i'll see what they have that I can make work.thank's
