Tool Talk Discussion Forum
Poulan 3400 carb specs.
Casey Sulak
05-10-2005 07:41:37
I recently acquired a poulon 3400 and went through it. It looked good inside the carb but will only start with full choke, wide open throttle and I have to rev it with the choke butterfly. I believe the carb is out of adjustment but I don't have the manual. Does anyone have the spec for the the high, low, and Idle screw adjustments. Thanks a lot!
none
05-12-2005 02:33:06
 Re: Poulan 3400 carb specs. in reply to Casey Sulak, 05-10-2005 07:41:37
If you can identify what carburator it is, it might help to go to the manufacturer website. Walbro and Zama have alot of info. The diaphrams on those will wear out, a rebuild may be needed. Fuel lines can get blocked too.
