Tool Talk Discussion Forum
Tire filler
Richard from SE
05-09-2005 23:15:26
I live in SE AZ and the prickly pear thorns, mesquite thorns, and goat head thorns make short work of my riding lawn mower tires. I am real tired of fixing flats. Those liquid tire sealers,slime for instance, don't work and only make a horrible mess. Im sure there is a product out there like a foam that will make my tires solid and thorn proof but I don't know what it's called or where I can find it.Please, any help?????
Nolan
05-11-2005 05:30:36
 Re: Tire filler in reply to Richard from SE AZ, 05-09-2005 23:15:26
Check around on the type of filler used. There's quite a variety. Some are hard, some soft. Some are even very heavy.
RJ-AZ
05-10-2005 18:46:07
Haralsons tire in Safford Az can do the foam fill. Maybe Marks tire shop in Willcox Az. We have the front tires on our ADOT mower tractors foam filled, Heavier thanheck but bulletproof.
JT
05-10-2005 18:22:56
The only draw back to foam filled tires on a lawn mower is they can make the tires very hard amd if you yard is rough, it is kinda hard on the frame, it also can be kinda hard on you also, rough riding.
George in Biloxi
05-10-2005 11:45:47
Some tire places will fill them up for $1.00 a pound of polyurathane foam. It hardens and you will never have a flat. I got tired of the wheel borrow and tiller having flats. They had a minimum and want $25.00 a tire. It would be worth it for you. Big tractor tires are around $400.00 each though.
Mike M
05-10-2005 05:51:22
Any tractor tire shop should be able to fix you up. Log skidders use a foam fill in the tires for instance.
Jerry (NH)
05-10-2005 03:29:47
Gemplers has a tire sealant that looks pretty cool and a little pricey. Never used it myself, but always thought it'd be fun to do a little product testing some day.
