Tool Talk Discussion Forum
adjustable front hitch
rockyhawaii
05-09-2005 18:35:38
I'd like to put a moveable trailer hitch on the front of a jeep. This would go up and down at the push of a button, and be visible from the driver's seat. It would not be used to tow on the road, just to move trailers around on some rough terrain. Maybe similar to a snow-plow rig. I'm thinking of using the works of a convertible top, or a three-point hitch. I can't spend a lot and have to make it myself. Anyone got an idea or done something similar?
Don L C
05-11-2005 18:49:35
 Re: adjustable front hitch in reply to rockyhawaii, 05-09-2005 18:35:38
The snow plow single hyd. lift idea will work fine...extend the arm out from the bumber about 12"....try truck 6" round mirrows with adjustable length arms, mounted on the bumper, will allow you to see the ball...
rockyhawaii
05-10-2005 11:09:19
I'd love to simply get an old tractor, but I'm in Hawaii and tractors are almost unheard of. I drool over the tractor ads on this site because that would be the perfect solution. The best I could get was a jeep, so I will build me a frame and plumb it. I won't use the convertible rig, I'll just bite the bullet and buy the hydraulics. Thanks.
Don L C
05-11-2005 18:55:17
 Re: adjustable front hitch in reply to rockyhawaii, 05-10-2005 11:09:19
A 12v pump and a small cyl.
Mike M
05-10-2005 09:22:38
This sounds like a perfect time to get that tractor you always wanted. Find one with a three point on it and your good to go.
ScottP
05-10-2005 08:44:07
Rocky
How far do you want it to move? Have you seen the set up they have on the back of the rigs they use to move trailer homes? They use hyd. cylenders mounted in a frame. Very slick. Where are you located? I have some hyd. cylenders that have been taken off various units that would work. Actually I have every thing you need. I'm in the S.F. Bay area. Let me know what you need. email is open.
Scott
Bob - MI
05-10-2005 05:15:40
I sold convertible top system components for a few years and I can tell you that the framework is too light duty for what you have in mind. Most of the rails and the #1 bow in a convertible are aluminum die-castings. There are some recent exceptions being magnesium. The walls are very thin for weight savings and the alloy is somewhat brittle. The engineering they put into them to get the top to fold is pretty slick however and it may be worth copying. Most of the tops out there have electic motors that actuate them but the Chrysler Sebring has a small hydraulic motor/pump system that makes it happen.
Good luck with the project
T_Bone
05-09-2005 21:15:51
Hi Rocky,
Probably the easiest is a mechanical lever between the seats (like a gear shift) that would run linkage on the front A-frame with a ball.
A boat doesn't have all that much tongue weight and with the first class lever it should be easy to raise from sitting in the seat.
Maybe a plate inbetween the seats with a notch so when the tongue is raised the orperating lever can be locked into the notch, then trailer moved, then lowered.
T_Bone
rockyhawaii
05-09-2005 21:35:00
 Re: adjustable front hitch in reply to T_Bone, 05-09-2005 21:15:51
T-Bone, here's the problem. I need to be able to lower and raise it gradually as I maneuver over some obstacles, in order to keep the trailer from digging in. It's a really crazy place that I need to maneuver the trailers. No tractiom or I'd use my forklift. A couble of "humps" of at least 8 inches, sidewalk curbs, and a tight area. Plus it's on a hill for part of the way. All in all it's pretty complicated, so I'm leaning towards something hydraulic, like on a farm tractor. Only cheaper, lol.
T_Bone
05-09-2005 22:15:01
 Re: adjustable front hitch in reply to rockyhawaii, 05-09-2005 21:35:00
Hi Rocky,
If it has a power steering pump, add a cylinder and a spool valve(ball valve would work) off that or add another PS pump.
T_Bone
rockyhawaii
05-09-2005 23:33:39
 Re: adjustable front hitch in reply to T_Bone, 05-09-2005 22:15:01
It has power steering. It would need a double-action cylinder, yes? I was looking at them in the Northern Catalog. Where in the system would it be installed? At the pump? In the line? I've heard of tapping off the power steering, but never seen a finished unit.
