Tool Talk Discussion Forum
Speed Queen Dryer
While on the su
05-09-2005 13:58:05
Does anyone know how to take the top off a old Speed Queen clothes Dryer? It looks simple enough but i just cant figure out how. I can overhaul a tractor, but i cant get this gosh darn top off to put drum roller bearings in. P.S. Iam to cheap to call a serviceman. Thanks
chvet73
05-10-2005 12:03:51
 Re: Speed Queen Dryer in reply to While on the subject of D, 05-09-2005 13:58:05
Bob has it correct. Most of them take a putty knife against the clip and a good tap on the knife releases it.
MAC,IL
05-09-2005 16:21:35
I aint for sure, If its the one that has the belt around the drum seems the back is all that has to come off.
john-mi
05-09-2005 17:17:38
 Re: Speed Queen Dryer in reply to MAC,IL, 05-09-2005 16:21:35
Mac,Il i had the back off and its all sealed. I am gonna try the other suggestions tomorrow. Thanks to all.
Steve from MO - dangit!
05-09-2005 14:08:42
 Stick your head in there. in reply to While on the subject of D, 05-09-2005 13:58:05
There are prolly some screws into the top from inside the upper lip of the door opening. It's hard to see or feel them unless you sit with your back toward the dryer and then lay back until you can get your head in the door. Once you know where they are, you can find them with a screwdriver.
Bob
05-09-2005 14:06:54
On some laundry appliances, you insert a thin tool, such as a putty knife, between the top and the front, and push it inward, towards the back, to release a flat steel clip that holds the top down.
Both sides need to be released.
On others, you take out a screw at each side, at the top back, and then the top slides forward or rearward, and releases from the front and sides.
