Tool Talk Discussion Forum
Tandem Trailor Question
Glenn FitzGeral
05-08-2005 08:03:21
Generally do all 10,000+ GVW tandem trailors have the axels set up with a center pivot? The alternative to this would simply be mounting the shackles to the trailor frame with each axel functioning independantly of the other. Thanks, Glenn F.
Gerald J.
05-08-2005 08:42:09
 Re: Tandem Trailor Question in reply to Glenn FitzGerald, 05-08-2005 08:03:21
Tandem axles with the equalizing linkage at the springs share the load much better. Independent axles won't necessarily share the load evenly unless the springs and tires are depressed equally. When the trailer is tilted or the road surface is tilted (think of going into a concrete driveway from a street with deep curbs). Without the equalizing link one axle and pair of tires can have to carry the entire load for a bit. Is breaking the tire and rim from that a good option? I think not. The link and its mount is whole lot less cost than that of tires and rims that can hack the total load of the trailer on one axle.
As a matter of history, early steam locomotives didn't use equalized axles, but they found maybe 140 years ago that going to the bother of equalizing links made them pull better and railroad track is a whole lot smoother than roads without rails.
Trailers including Airstreams are made without equalizing links. Some have problems with short tire life, which I believe may be as much from the lack of equalization as from problems of axle alignment.
Gerald J.
txgrn
05-10-2005 06:14:27
 Re: Tandem Trailor Question in reply to Gerald J., 05-08-2005 08:42:09
One would think that Airstream of all people would put the best axles under their "upper cut" trailers.
Mark
Gerald J.
05-10-2005 08:18:52
 Re: Tandem Trailor Question in reply to txgrn, 05-10-2005 06:14:27
At about $950 an axle for replacements the Henschen torsion axles (copied by Dexter these days for 1/ the price) "MUST" be superb. They are full independent suspensions and but they don't equalize the load between axles. Some Airstream owners run tires 5 to 8 years with no problems, some blow tires every year. And the suspensions have hardened and sagged on the true vintage trailers leading to a harsh ride until the axles are replaced. And to even poorer load sharing between multiple axles.
Gerald J.
Glenn F.
05-08-2005 08:14:21
While I'm sure the center pivot is better, is it satisfactory to have each axle mounted separately? Thanks, Glenn F.
720Deere
05-08-2005 09:04:43
 Re: Tandem Trailor Question in reply to Glenn F., 05-08-2005 08:14:21
I think you will find the results to be less than satisfactory. A 10,000 lb trailer is way to heavy to not be equalized. Even if each axle is rated 7,000 lbs, there will be times that 100% of the weight is on one axle effectively overloading that axle by nearly 50%. My experience with seperate mountings on tandem trailers is that tire wear is very excessive and bearing life is short also. With the seperate mountings, even something as simple a vehicle hitch height will affect axle loading. The traler may be level when empty, but if the truck sinks any when loaded, you will effectively be loading the front axle of the trailer more than the rear axle which will lead to excessive tire wear on the rear axle and bearing failure on the front axle.
An equalizing pivot is so easy to design/fabricate, why would you not want to do it?
txgrn
05-09-2005 06:21:36
 Re: Tandem Trailor Question in reply to 720Deere, 05-08-2005 09:04:43
I went to a trailer shop the other day to redo the undercarriage on my stock trailer. I got the whole shooting match in a box for $21. Had the brackets you weld to the frame, the equalizer casting, and all the hardware. Whadda deal.....of course it was made in China. Where else for $21? The price told me before I saw it on the box.
Mark
Glenn F.
05-08-2005 12:31:03
I am looking at a homebuilt one thet doesn't have one. If nothing else, adding one would probably raise the deck 4". He did a nice job on this one but no pivot. Actually it's got two 6,000# axles. Glenn F.
