Tool Talk Discussion Forum
Pressure Washer - Honda
Don L C
05-07-2005 09:53:08
I have a 2300# pressure washer with a Honda engine...the owners manual states not to let the engine run whe you release the trigger, for any length of time ,because that creates heat....you guys that have washers,how long do you let yours run with out the trigger pulled ? what would be the max time ? THANKS Don
550Doug
05-07-2005 13:12:09
 Re: Pressure Washer - Honda in reply to Don L C, 05-07-2005 09:53:08
A Honda dealer told me a maximum of 3 minutes without cooling the pump will damage the pump. This was on a 3000 psi unit with a 13hp Honda motor. I just tie the trigger open on the wand when Im outside.
Davis In SC
05-07-2005 10:19:26
I try not to let mine run under a dead load for over a minute, if I can help it. Also, after I stop the engine, I keep trigger open for a few minutes so water can flow & cool pump down.....
Don L C
05-07-2005 18:35:27
 Re: Pressure Washer - Honda in reply to Davis In SC, 05-07-2005 10:19:26
Thank you for the comback,that is what I needed to know.....by the way I think I'll make a lock out to keep the valve part ways open, at all times..... ..... .
Davis In SC
05-07-2005 21:34:07
 Re: Pressure Washer - Honda in reply to Don L C, 05-07-2005 18:35:27
Don, I am no expert on pressure washers, but I think, from the way the unloader valve works, that trigger needs to be either full on, or full off..... Davis
Don L C
05-08-2005 07:28:23
 Re: Pressure Washer - Honda in reply to Davis In SC, 05-07-2005 21:34:07
Davis..... thanks a lot.....I'll check futher, before trying it..... .Don
