CAREFULLY is the short answer. Those things will break bones. Although protected, your local conservation officer can and should give you a nuisance permit for the asking. Sometimes they'll balk, but if you push a bit you'll get one. Be sure you do, too - or you'll be having unpleasant conversations with them in the near future. Bunny huggers are everywhere looking out for the poor beavers! Anyway - Squeeze the springs together with setting tongs or strong arms. You can also use a rope trick. Tie a loop in one end of a 1/4 inch nylon rope. Put your foot thru the loop, thread the rope UP thru both spring eyes, back down the outside and back up thru the spring eyes again. When you pull the free end, it will squeeze the springs together fairly easily. Hook the safety loop and repeat on the other side. Lay the trap out flat, and pull the jaws apart. They will finish compressing the springs. When they are close together, put the notched dog over the trigger on the other jaw. MAKE SURE THE SAFETY CATCHES ARE STILL ON THE SPRINGS. (they fall off easily) If that trap goes off before you're ready, you're going to the hospitol. Put your trap in the center of the ditch, and stabilize it with sticks. Put a bigger stick over the top so the beaver will dive under the stick and thru the trap. Wire it to something HEAVY or sturdy with HEAVY wire, Then and ONLY then do you CAREFULLY remove the safety catches and slide them to the ends of the spring away from the trap. Good Luck!
