Tool Talk Discussion Forum
Parts washer solvent
Chris Jones
05-06-2005 20:02:20
I'd like to know what you guys use for solvent in your parts washers. I was using kerosene but that didn't work good enough. I then bought some "Concentrated Degreaser" from Harbor Freight. It is made by Genlabs and is mixed with water from 1 to 8 to 1 to 150. I mixed it 1 to 20 and it was worthless. I'm trying it mixed 1 to 3 now but I'm not impressed. I need to find an economical solvent and would like it to be environmentally friendly.
Any ideas?
John T Horner
05-08-2005 06:50:30
 Re: Parts washer solvent in reply to Chris Jones, 05-06-2005 20:02:20
I use mineral spirits in my parts washer and it works pretty well. There are more agressive solvents out there, but I am happy with mineral spirits. Any good paint supply place will have it.
John
Don L C
05-07-2005 18:37:53
Try "SIMPLE GREEN"----get mine at LOWES....
Davis In SC
05-07-2005 10:24:30
Normally I use Graymills Agitene 141, it works great. Recently, I ran out & bought some other brand at Advance Auto. It did not clean parts near as well,& it is much more irritating on my hands..... .
hogman_2002
05-06-2005 21:44:21
I use some stuff from Tractor Supply Company. It's worked good so far. It costs about $21.99 per 5 gallons.
720Deere
05-08-2005 08:55:41
 Re: Parts washer solvent in reply to hogman_2002, 05-06-2005 21:44:21
I will second the TSC stuff. It is about as cheap as anything that I have found and works as good as the professional stuff that I have been around.
RWT
05-06-2005 20:45:48
Ask an oil supplier that handle fuels and lubricating oils for a parts cleaning solvent. I haven't tried lately but I am sure I could get it from at least one of the 3 companies here.
When I still had the shop I would buy it 55 gallons at a time. Cheaper by the gallon that way and the washer would hold it. I would think you could buy a gallon on up. There's a good chance you will need your own container (unless you buy 55 gallons).
RT
Big Jim
05-06-2005 21:42:04
 Re: Parts washer solvent in reply to RWT, 05-06-2005 20:45:48
I head down to a local bulk plant with my 5 gal jugs. Pull up to the pump that is labeled SOLVENT. Pump and pay.
lucasss
05-06-2005 20:38:52
mineral spirits is 2.00 a gallon at walmart, i find it to be a good all around solvent for parts washer. lucas
BobPA
05-06-2005 20:11:16
I like to use Castrol Super Clean on grease and crud. It is OK for environment but I don't have a parts washer.
Jerry Cent. Mi.
05-09-2005 16:02:00
 Re: Parts washer solvent in reply to BobPA, 05-06-2005 20:11:16
How do you get rid of the solvents when they get to dirty to use any more?
