Tool Talk Discussion Forum
OT/ Dump truck part
Carol Martin
05-06-2005 04:42:31
Hi I have a little problem; I have a 1967 C50 Chevy Dump truck and need a part.. Have called every dealer around this area and cannot find any one with a parts book for it..The part that I need is in the Clutch linkage.. There is a Z-bar rocker with a swivel on each end.. I need a new swivel post ( this screws into the bell housing and the Z-bar slips over this post.. the other end of the Z-bar is attached to the frame. More than likley the part is available just that I cannot find a part number for it and the dealers cannot or will not help. Would appreciate any help with this..
Thanks..
Carol
greenbeanman in Kansas
05-08-2005 08:22:01
 This catalog lists them. in reply to Carol Martin, 05-06-2005 04:42:31
The online catalog for Jim Carter Classic Truck Parts shows them available.
At the link below click on the appropriate year catalog. The index is on pages 6-7 (top right).
The clutch items are on pages 61-62 of the year catalog you want.
One more thing, just click on the index or other page to increase the size of that page.
Carol Martin
05-08-2005 12:34:20
 Re: This catalog lists them. in reply to greenbeanman in Kansas, 05-08-2005 08:22:01
Hi Thanks for the Link.. But I think this is the ball for the clutch Fork not the one in the linkage will give them a call see if they have what I need.
Thanks
bigwood
05-06-2005 19:14:39
 Re: OT/ Dump truck part in reply to Carol Martin, 05-06-2005 04:42:31
Try Windy Hill auto parts 320 354 2201
wdtom
05-06-2005 18:31:39
Could you make won with a lathe, or a friends lathe? I know it would be more work than buying one, buy if you are spending a lot of time looking, well an hour or two at a lathe might save you time. Only thing, is it heat treated? If so this changes things a bit, buying one is the way to go. Used or new.
Dennis in Wisconsin
05-06-2005 17:22:01
If you can*t find one around home let me know because I*m pretty sure I have one in the tool box. I don*t know if there all the same size though. Mine came out of a chevy half ton. good luck Dennis
Carol Martin
05-06-2005 18:32:04
 Re: OT/ Dump truck part in reply to Dennis in Wisconsin, 05-06-2005 17:22:01
Hey Dennis.. The one I need is 2 1/2 long the ball is 7/8 and the thread is standard 1/2 in.. If you have one would be glad to buy it from you.
Carol
OK-AL
05-06-2005 14:52:58
Carol,
I believe the pivot ball is the same for the big trucks of that era as the pickups. I've bought a lot of stuff from ChevyDuty.com They're a classic truck parts supplier. I'm sure that they will have the part you need.
If not, try another Chevy dealer. Sometimes you have to go to two or three in order to get someone who'll help you.
Good luck,
OK-AL
Old Dutch
05-06-2005 14:43:24
Carol, Know the part your talking about I believe. Is it the pivot ball? A stud that is in the bell housing? The clutch push rod contacts that lever to release the clutch. If that is what you need their should be jillions in the salvage yards or even in some ones back yard. They were all the same from who knows when. That truck probably doesn't have anything bigger than a 265 cubic inch engine, and if bigger it would still have that paddle pivot arrangement. Go for it Buddy there's lots of them around. Old Dutch
rockyhawaii
05-06-2005 09:35:28
I bought one of those studs from a Jeep dealer, so I know they are available. If the Z-bar size is the same, I'd buy one from wherever I could find it. As many old trucks that are sitting in fields, I'd check those too.
Dick Kline
05-06-2005 09:08:05
This may sound silly, but have you checked Corvette parts sites. A Chevy motor is a Chevy motor and if you could identify it from a picture, they might be able to help you.
Just a thought..... ..... .
MAC,IL
05-06-2005 06:43:37
SOmetimes these dealer parts just dont want to co=operate with a guy. If it is that ball thingy that screws into the housing, they are out there.
Found this, may give you something to check out.
Link
copy and paste this one.
hay
05-06-2005 06:11:32
try NAPA auto parts. they have many older parts for big trucks and tractors.
carol Martin
05-06-2005 06:36:46
 Re: OT/ Dump truck part in reply to hay, 05-06-2005 06:11:32
Tried NAPPA and O'rieleys This is strictly a dealer part. all of the dealers around here say they dont have any parts books going back that far. cannot locate a junk yard around here in So Mo that handles many truck parts. Tried couple of on line sites and got no response from them.
Maxgussam
05-08-2005 17:44:59
 Re: OT/ Dump truck part in reply to carol Martin, 05-06-2005 06:36:46
Try www.car-part.com never failed to find a part I need when I use it. You can post in the "wanted" section, and you will be bombarded with offers to sell you the part you need...
david - OR
05-06-2005 09:54:54
I owned a 1967 Firebird (Camaro with a different engine) years and years ago. I remember the clutch linkage was similar to what you describe for your truck. A quick Yahoo search on "Camaro clutch parts" quickly turned up this item:
Link
I believe this part is at least the same idea as what you describe. I'm not saying the part is the same or that the vendor is any good, but maybe it will at least give you a picture for what you are looking for.
A junkyard might have a Hollander Interchange manual that could cross the C50 part with other cars and trucks, which would give you a bigger pool to work from.
