Tool Talk Discussion Forum
700R4/4L60 GM transmissions
CNKS
05-04-2005 18:04:32
I tow with my 1992 GMC half ton 350 CID in 3rd gear -- it shifts in and out of lockup too often. I am within both the towing capacity and the combined pickup and trailer weight (which are optimistic, unless I have a flat road and no wind). B&M theoretically has a kit that will keep it locked up until I turn it off. This may not be a good idea as my understanding is the transmission is designed to shift out of lockup as needed, ie, if the accelerator is depressed, or on a slight grade. On level roads, the transmission runs cooler when in lockup because of more fluid flow. Hotter when out of lockup. Shifting in and out worsens the heating problem. Going to add a larger external cooler to lessen the problem, but will still have the shifting on hilly roads or against a headwind. Yeah, I know, get a bigger pickup. But, does anyone have any thoughts on the feasibility of keeping it in lockup longer, and is anyone familiar with B&M's kit -- Summit, who sells it and the B&M factory rep have differing opinions on whether or not it will work -- don't think either of them know what they are talking about, and I don't either.
Lil-Farmer
05-05-2005 20:18:34
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-04-2005 18:04:32
CN,
I have an '89 Suburban with the 700R4 and 3:73 rear gears. Not 4 W/D. About half of my miles are towing an 8500 lb trailer. First tranny lasted less than 60,000. Shop that rebuilt it suggested a device(can't recall the name, but will check if you want) that keeps the TC out of lockup unless the trans is in OD. If manually run in 3rd, the TC will never lock. Along with that they suggested a shift kit and an oil pan available from Summit Racing. It is cast aluminum with fins on the bottom, a drain plug, and holds two extra quarts of oil and a large, external oil cooler. I change tranny oil every 30,000, not the filter, just drain and refill. Never dark or smelly.
I am happily motoring towards 200,000 on that tranny and have had NO trouble. Fuel mileage might suffer just a little when towing without the lockup TC, but I can live with it. About 9 MPG @ 65 MPH highway. Not towing highway mileage between 16-17.
CNKS
05-06-2005 06:50:59
 Re: 700R4/4L60 GM transmissions in reply to Lil-Farmer, 05-05-2005 20:18:34
I have the B&M steel pan, not the aluminum, it holds 2 more quarts -- might help but not enough. I have an external oil cooler, adding a 2nd one today. Does your shift kit shift smoothly? BuickandDeere, in this thread below likes them. Does it decrease slippage? -- otherwise I don't understand how it helps except to reduce slippage when shifting. I can put the switch on to keep it out of lockup in 3rd, but my understanding is that you want it in lockup, as long as you are not lugging the engine. Mine shifts out too soon in my opinion.
Lil-Farmer
05-06-2005 23:32:00
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-06-2005 06:50:59
Yes, the shift kit makes the shifts more firm, but not annoyably (is that a word?), in my opinion.
Yes, the TC is now slipping instead of being locked up, but again, in my opinion, this probably generates less heat than the TC constantly shifting in and out. You are also carrying more engine rpm which increases pump speed and therefore flow through the cooler and to other internal trans parts.
It has worked and worked well for me. Your mileage may vary.
Allan in NE
05-06-2005 07:11:05
CN,
The 4L60 is not a stacked shift where gear changes are additive, one on top of the other, like the old 400s or newer 4L80 transmissions are; but rather, the 700 uses a "timed" shift.
What this means is that for every gear change, it requires one friction set to 'release' at the same time another is 'engaging'. There is always going to be a certain amount of "slipping" during a 4L60's shift. It is the nature of the beast. Put a heavy trailer on behind that truck, and this shift 'burn' is magnified.
What these shift kits do, is to monkey around with the engineering of the springs, weights, pressures, etc. to "shorten" this 'shift/burn time'. End result is always a "stiffer" shift.
Works better when towing; trouble is, when you unhook the trailer, that "stiff shift" itself is then magnified resulting in a somewhat 'harsh' shift.
Since automatic transmissions were never, ever designed to tow, we can't have our cake and eat it too; we have to find a somewhat happy medium and learn to live with it.
Allan
Allan in NE
05-05-2005 19:06:41
Hey CN,
Why don't you just put a tranny heat gauge in your truck. Keep 'er under 270 degrees and leave the truck like it is. It sounds to me like your truck is operating just as it should.
Let the darned TC shift; that is what it was designed to do.
Allan
CNKS
05-06-2005 06:05:01
 Re: 700R4/4L60 GM transmissions in reply to Allan in NE, 05-05-2005 19:06:41
I have a gauge -- ran 250 last time. Oil was brown, oil out vent pipe, trans is supposed to run cooler in lockup--oil flow is better, with proper cooling as you say, it probably doesn't matter. Towing weight last time was "only" 5000 lbs, 25 mph head/crosswind--very typical for where you and I live.
Allan in NE
05-06-2005 06:30:00
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-06-2005 06:05:01
Yes, a locked converter does not generate the heat like it does when unlocked.
Where is your gauge hooked up?
It should be reading right at the output of the cooler line connector at the tranny. This oil is coming directly from the torque converter and also, it is in the torque converter where the heat is generated because of all the 'slippin'/sliddin' reduction going on in that converter.
The reason I ask is because if you have it hooked into the return cooler line, you are reading oil that has already been "cooled" out front and this would be kind of a false indicator.
At 250 degrees, like you say, things are starting to happen like the oil turning brown color and wanting to puke, but you are still okay.
Allan
CNKS
05-06-2005 06:55:12
 Re: 700R4/4L60 GM transmissions in reply to Allan in NE, 05-06-2005 06:30:00
It's not hooked up at the pressure line, it is hooked up to what is called the "pressure port", where they attach a gauge to check pressure? It sure reads hot enough for me. I have seen it go to 200 degrees, no trailer, hot weather in stop and go traffic. Reads 160-180, unloaded on the highway.
Allan in NE
05-06-2005 07:42:42
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-06-2005 06:55:12
Aw, that explains it.
Couldn't really figure out why you were gettin' brown oil at only 250 degrees. This usually starts showing up at around 280 degrees.
That pressure port is just one step away from the coolest part of the transmission, the sump.
Tempreatures over at the cooler line out will be showing higher than that. A 'cool' transmission running down the road will always show around 200-225 coming off that converter (depending on the conditions, of course).
A "stock" truck will always have tranny temps running at least at the 195 degree mark because this is the temp the truck's thermostat is set at and is as cold as that radiator's tranny cooler can get it down too. Follow me?
Allan
CNKS
05-06-2005 10:02:51
 Re: 700R4/4L60 GM transmissions in reply to Allan in NE, 05-06-2005 07:42:42
So, should I bypass the radiator -- I am installing a 2nd cooler at the moment. Is the pressure line out of the tranny to the cooler the bottom fitting on the trans -- my books say so, the instructions for the cooler says so, the tranny guy, who like yourself makes a living at it says the hot line is TOP fitting. Think I'm going to forget towing and buy a bicycle.
Allan in NE
05-06-2005 12:26:38
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-06-2005 10:02:51
Hi CN,
Doggone! Sounds like an ordeal goin' on down there in Kansas today. Ha!
No Sir, your tranny guy is wrong. The bottom line is pressure out. Transmissioin coolers work exactly backwards of radiators in that the flow is from bottom to top.
I'd sure leave in the radiator cooler; the more cooling, the better, I'd think.
Allan
CNKS
05-06-2005 17:03:28
 Re: 700R4/4L60 GM transmissions in reply to Allan in NE, 05-06-2005 12:26:38
That's what I thought -- I added a 2nd cooler today, pressure line to bottom of radiator, return top and then to cooler. The 1st one was installed by a mechanic 3 or so years ago, he went to the external cooler 1st then to radiator, I changed that. Drove about 10 miles, barely got to 165 (no trailer) -- need to experiment with a loaded trailer. Going to put in synthetic trans fluid and see if that helps-"supposed" to resist heat better.
Redmud
05-05-2005 09:20:10
CNKS, You do know? that when you apply the brakes, it kicks out of lockup, so try lifting the brake pedal with your toe when the lockup is kickin in and out. After a GM is a few years old, the brake pedal will droop a little from worn bushings, the pedal return spring will loose tension, and the pedal switch is still where it was when the truck came from the factory. add a little road vibration to the pedal, And It will drive you crazy with the lockup kicking in and out.
CNKS
05-05-2005 09:37:19
 Re: 700R4/4L60 GM transmissions in reply to Redmud, 05-05-2005 09:20:10
Thanks, I'll try that, except it will stay in lockup on the same road empty and will go out when pulling. I'll try that next time I have it on the road, though.
Allan in NE
05-05-2005 04:04:22
Mornin' CN,
I lived off those trannys for 20 years; rebuilding 700s was how I made my living.
You are doing everything right. Forget the lockup kit and put on that external cooler you speak of. Not the pretty flashy one from NAPA, but the big, black, thick, square guy from GM.
Also, I'd use steel brake line and compression fittings to pipe it in. Hoses and clamps just aren't meant for heavy service, especially in the wintertime. That thick oil will blow a hose off and you loose the transmission.
I've seen those converters get so hot that they have turned blue and you could smell that hot iron/oil 1/2 a mile away. That scrawny little radiator cooler just cannot get the heat away from 'em, even tho the dealer told you that it had the "tow package".
Allan
third party image
CNKS
05-05-2005 05:36:11
 Re: 700R4/4L60 GM transmissions in reply to Allan in NE, 05-05-2005 04:04:22
Thanks Allan -- Further details, this is a 4WD the axles are 3.42's. I have towed enough with this truck, under enough conditions of grade, wind, trailer weight, etc to think that 3.73's would be adequate for my needs. I have figured rpm's in all gears at different speeds. "Tow capacity" (quotations are factory specs for ideal conditions, not real world towing) are 6000 lbs for 3.42's, 7000 lbs for 3.73's and 8500 lbs (not sure I believe that one) for 4.10's. I don't want the 4.10 because the truck is unloded 99% of the time, and in my opinion, the rpm will be higher than desired for daily use, although the 4th OD is probably ok when I'm not towing. I was going to change to 3.73's until the local mechanic says he does not want to mess with setting the gears in the front axle, seems it is more complicated than the rear, so he recommends getting a complete 3.73 axle from salvage. I found one that has more miles on it than my existing one -- I really don't want to do that. I have an external cooler, have a 2nd on order. One cooler does not do the job when bucking a 20-30 mph wind. Going to connect them in series, both are about 24000 lbs GVW (rather meaningless numbers). Should I run them thru the radiator cooler 1st, last or bypass it? The guy that installed ran it thru the external 1st, then thru the radiator, to me that's backwards. I'm going to use synthetic oil in the transmission, which should run cooler when hot, and flows better when cold. So, overcooling unloaded in a typical Kanss winter should not be a problem, as the synthetic is supposed to flow better when cold. Seems to me that the lockup would help, if it would stay in a little longer and not kick out out the slightest hint of a grade -- it would probably work better with 3.73's. The trans has overheated a few times. When it does, I change the fluid. Sooner or later it's going to fry -- Since you have rebuilt them, has the previous overheating done enough damage that it now overheats easier, than when newer, and would a rebuilt trans run cooler? As far as I'm concerned the transmission works perfectly towing or not, except for the lockup shifting in and out, it has done that since new -- Sorry for the long post.
John T Horner
05-08-2005 07:08:20
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-05-2005 05:36:11
I think that the reason transmission coolers are often installed before the radiator is to minimize the chances of overcooling the fluid in light load conditions as the radiator will warm it back up before sending it on to the transmission.
In heavy load conditions, cooling the transmission fluid first is also a good idea because it reduces the heat load on the engine cooling system.
I would certainly hook the auxiliary transmission cooler in ahead of the radiator.
Synthetic transmission fluid is an excellent idea for towing. I would also run synthetic lubes in the differentials if doing lots of heavy towing.
John
Allan in NE
05-05-2005 18:54:36
CN,
The 3:73s are the best "all around" ratio for that year of truck in a 4x4 version, but that is one heck of a job swapping the ratios; I've done it and that front differential is nasty if you haven't been schooled on 'em. Also, you would have to change the prom because otherwise, the computer thinks you still have the 3:42s. I'd just leave it alone.
GM finally got that tranny right in the '91 and '92s before going electronic. You've got a tough tranny.
I like to run the cooler oil thru the radiator first, then the auxirally, then back to the dump. The cooler, the better when it gets back home.
Allan
CNKS
05-05-2005 20:01:27
 Re: 700R4/4L60 GM transmissions in reply to Allan in NE, 05-05-2005 18:54:36
Thanks--Will cost about $1500-$1800 to have the gears changed -- have to get a salvage axle for the front because the people I've talked to say the front gears are too hard to set -- doesn't have a simple cover like the rear. You have actually swapped gears in the front? No one I have talked to wants to do it. The ECM does not work on the transmission except for the lockup torque converter, I thought all that needed to be changed was the speed sensor (or whatever it's called) for the speedometer, if I have to change the ECM, forget it. Still arguing with myself about this. On paper the 3.73's will give me another 1000 lbs of towing capacity-7000 lbs on flat ground. Actually, I have already towed 7000, once -- that's the last time I'm going to try it with 3.42's. Changed the tranny fluid enroute -- otherwise I believe the trans would have cooked.
Allan in NE
05-06-2005 06:09:35
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-05-2005 20:01:27
Mornin' CN,
Yes Sir, you're right; on a '92, there is no shifting on command from the ECM and the shifting is controlled via that �other� throttle cable that controls the TV pressure against governor pressure and the various shift valves� spring pressures.
However, all that VSS is, is a little electrical A/C �generator� that picks up the tooth count on the output shaft. Changing this item will do absolutely nothing for the correctness of your speedometer or the torque converter�s locking/unlocking strategy, as all VSS units would throw the same identical count for any given reluctor ring. You have to change the PROM inside the ECM to get that ECM to �decipher� and �understand� that thrown count correctly for any changed differential ratio.
Yes, setting up the backlash and the bearing preload is just plain �nasty� in that type of front differential. I�d personally trade trucks before swapping out the ratios.
On that particular transmission you have in your truck, it�s only enemy is heat. At 305 degrees, the bonding on the clutch discs begins to melt and she comes down. Keep it cool and let it shift as it was designed to do (to provide you with the proper acceleration) and it will last a long, long time.
Allan
MSM
05-05-2005 03:38:23
The truck is probably operating at the very upper limits of it's capacity especially if it is geared numerically high(2.76 or 308 etc)You should install the cooler as indicated,but also consider going to a lower rear gear set,possibly 4.10's and change the speed sensor to match the gears if you do to . You need to keep the rpm up some,especially when towing. Operating at low rpm in lockup is not good for the trans or converter.Constant shifting in and out of lockup is also detrimental to the converter. Line pressure and volume of fluid moving through the trans and cooler is reduced which will cause overheating of the converter,and trans.Forcing the trans to stay in lockup by the addition of a shift modifer will only be a tempory fix and may very well lead to other problems down the road.
billpa
05-04-2005 22:33:04
try replacing the tps.
Bob
05-04-2005 21:33:30
On a 1992, the engine computer has the final say an torque convertor lockup.
The computer senses engine load by accelerator position and manifold vacuum, sensed by the MAP sensor.
So you can have a perfectly good transmission, and have a heavy load, and maybe a engine with some miles on it, and when the computer decides the engine is lugging too hard, the computer will unlock the torque convertor. (Numerically LOW axle ratios will make the engine lug more, and the computer will unlock the convertor sooner.)
If you have access to a scan tool, you can see the computer's opinion on convertor lockup at any given time.
If it unlocking is intermittant, and not load-related, check and adjust, or replace the brake switch.
The aftermarket kits simply supply a steady current source to the lockup solenoid, regardless of the engine computer's opinion of whether the convertor should be locked or not.
Dean Barker
05-04-2005 21:16:15
I am no expert also, but it seems like a good idea to keep the transmission torque converter in lockup all the time to reduce slippage and thus heat. If the engine is lugging, then 2nd gear lockup seems like the best choice. I have a 96 6.5 diesel with the 4L80 transmission and it seems like that transmission is in unlock mode too much of the time.
rockyhawaii
05-04-2005 19:09:35
I had a 700R rebuilt for a blazer, using the B&M kit. The shop told me the lockup kit wasn't worth putting in. I now drive another 700R transmission, and my owner's book says not to tow in overdrive. It even has a Tow button on the gearshift that I assume keeps it from going in and out of lockup.
CNKS
05-04-2005 18:11:56
The kit I am referring is on page 9 of the PDF file in the link -- if you have dialup, you may not want to wait on it.
OK-AL
05-04-2005 19:14:40
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-04-2005 18:11:56
I'm not an expert at this, but here's my $0.02 worth:
When you say Lock up, do you mean the lock up torque converter? Or are you trying to drive in overdrive and the transmission is shifting in and out of overdrive?
Never tow with a 700R4, 4L60, or 4L80 when in overdrive. Always tow in 3rd gear.
If you're towing in 3rd and the torque converter clutch is unlocking, then that could indicate a problem with the transmission or torque converter. As I understand it, the torque converter clutch locks up at a pre-determined vehicle speed regardless of load. If that's true, then I don't know why it would lock and unlock while driving at a steady speed.
Like I said, i'm not an expert, but I hope this helps. Maybe some of the others know more than I do.
OK-AL
CNKS
05-04-2005 19:55:12
 Re: 700R4/4L60 GM transmissions in reply to OK-AL, 05-04-2005 19:14:40
I'm aware not to tow in overdrive. I mean it shifts in and out of the torque converter lockup in 3rd gear. On level roads, no wind, it stays in lockup until I press the accelerator, or there is a fair sized hill, as it's supposed to. Otherwise the engine would lug. In the wind or on a very slight grade -- the "grade" isn't even noticeable if I'm not towing -- it either shifts out of lockup and more or less stays there until the road is perfectly flat, or shifts (hunts) in and out depending on how much wind there is. Both of these situations generate heat, as the torque converter "slips" when out of lockup. My question is, will the B&M lockup wiring (not to be confused with an internal "shift kit") keep the converter locked up on slight inclines? Transmission is as good as new, far as I can tell.
OK-AL
05-05-2005 18:44:25
 Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-04-2005 19:55:12
I don't know about computer PROMS or add-on kits for the torque converter lockup. But, switching to 3.73's should fix the problem. But, you'll have to change both the front and rear gears. I wouldn't be afraid to use the salvage yard gears. I changed out a '67 Chevy 3/4 ton rear gear from a salvage yard truck and they work great. No noise, no problems. Who knows how many miles the salvage truck had on it. (The instrument panel was long gone!)
Good luck,
OK-AL
buickanddeere
05-05-2005 05:51:06
 Yes but..... Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-04-2005 19:55:12
Changing the E-Prom chip in the VCM/PCM/ECM will widen the "deadband" of the torque convertor lockup. That is a significant change in speed or load will cause the lock/unlock to occur. Rather than minor speed/load changes causing lock/unlock you have now. The torque convertor has lockup available when the trans oil has and engine reached operating temps. Then load/gear/rpms etc control shifts etc. There is also a failsafe over temp circuit that locks the torque convertor to reduce heat input should the trans oil get too hot. As for the shift kit, that increases line pressure and reduces overlap/slipping during shifts. A good idea. There are HD lock-up torque convertors that are designed to take full engine torque of a race engine. "Orange Crush" or something was one of the names. It would be cheaper to trade trucks than swap gear ratios.
Rick Bell
05-13-2005 12:06:23
 Re: Yes but..... Re: 700R4/4L60 GM transmissions in reply to buickanddeere, 05-05-2005 05:51:06
i have a 1983 Trans Am with a 700r4, and it began to not move when i shifted into any gear. every once in awhile it would catch and move alittle, but then would stop. I removed the tranny and checked the pan, there was no sign of any gear damage, so i put on a new filter and gasket and reinstalled, along with a new torque converter. Still does the same thing. Anyone have any idea ? Could it be the rearend ? Thanks, Rick
CNKS
05-05-2005 07:02:34
The only computer control for my trans is the lockup, so the ECM has no effect, unless you are talking about some of the "full-throttle" chips such as Jet. In other words, there is no kit to "reprogram" my 1992 ECM, far as I know. There are kits for GM'S vortec, I have TBI. I really don't want to put a shift kit in the trans. I am asking specifically about the lockup "adjuster" I referred to in my 1st post, or others that I don't know about. Changing the front and rear axles will cost $1500-$2000+, depending on exactly what I have done-no desire to do it myself. Trade-in value of my 13 year old pickup is about $4500, new ones with rebate, trade and taxes are about $30000, less if I go to a large volume dealer 200 miles away. Used trucks are avalable--really don't want to go that route. Except for a few squeaks and rattles, my 1992, 83000 mile truck is "like new", and has been well maintained. I am trying to set it up for occasional towing, couple of times a year at most, probably less -- can't justify a new truck for that. But, I might be willing to spend a couple of thousand, provided it works, that's why I'm asking.
buickanddeere
05-05-2005 08:32:19
 Re: Yes but..... Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-05-2005 07:02:34
The after market chip(s) control the torque lock-up. They also alter some of the tables all through the operating range, not just w.o.t . Instead of for example locking at 42 mph and unlocking at 40mph. It may lock at 45 mph and unlock at 40mph. So less "hunting", heat and wear. Feels better to drive too. I don't know what you mean about the lock-up adjuster? There is a spool valve similar to what is used factory origional in FireBirds etc that allows overdrive and I think torque lock-up at high speeds and at lots of throttle. There is also a kit to just eliminate the us eof the torque convertor. That costs in heat and lowered fuel mileage. The shift kit works and works well.Less heat, less wear and some shift points can be adjusted to better match the engines power band/axle ratio.
CNKS
05-05-2005 09:18:42
 Re: Yes but..... Re: 700R4/4L60 GM transmissions in reply to buickanddeere, 05-05-2005 08:32:19
The lockup adjustment thing is on page 9 of the attached pdf file. Also on page 184 of the Summit catalog hard copy. I have talked to the supplier, Summit Racing, who said it only determined the speed at which lockup occurred, and a person at the B&M headquarters that said it would stay in lockup until disengaged -- the description of the product does not specifically say that. I don't think I need a shift kit. The transmission works as it is supposed to, shifts are still firm up and down. The ONLY problem is the early shifting in 3rd or 4th converter lockup, that I would like to change so that it will stay in lockup a little longer. 3.73 gears would solve the problem. I was all set to do that until I found I would have to change the whole front axle -- or else find someone willing to change only the gears.
buickanddeere
05-05-2005 21:04:43
 Re: Yes but..... Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-05-2005 09:18:42
Those switches are intended for retrofits of lock-up torque converter transmissions in vehicles that were equipped with such from the factory. The other use is in drag racing. To improve trap speed and yet avoid lugging the engine. The ground speed is known in high gear when the engine is approaching or past the peak of it's torque curve and well up on the HP curve. When say in high gear and 5000 rpms the ground speed signals lock-up. Work well enough there too. In your application the rpms will drop as the converter locks. Engine rpm will drop and the torque will unlock. There will be multiple shudder applications/disengagement's until she finally gains enough speed & locks How about what the heavy equipment automatic transmission manufactures do? Torque lock-up is not based on ground speed but engine rpms of peak torque and peak HP. A MSD rpm sensing module with a "window" or what we call in the I&C business as "dead band". No matter what the gear, if engine rpm is too low. The converter will not apply until the engine is into it's power band. No hunting or shuddering either. I'm wondering why you are not keen on an upgrade chip in the VCM to improve torque lock-up parameters. It will make a few more HP too.And why you are not interested in a shift kit to reduce slippage/heat?
CNKS
05-06-2005 06:19:46
 Re: Yes but..... Re: 700R4/4L60 GM transmissions in reply to buickanddeere, 05-05-2005 21:04:43
Truck is used mostly for NOT towing -- my understanding is -- correct me-- that shift kits in normal light duty use make the trans shift rough -- the hot rodders like that, I'm not one of them. My trans shifts very smoothly, loaded or not, with a slightly rough 1-2 upshift when cold, less noticable when hot. Everything is a compromise. I'm trying to maintain my light duty highway performance and still increase towing ability, may not be possible. You may correct me on this too, and I have not checked chips lately, but the last time I looked, the chips for the 92 ECM were full throttle applications. The later models have reprogrammble computers -- if you know of one for a 92 350 TBI, let me know where to look -- And, I'll do a Google search for one. Although I like my pickup, and it is in good condition, it is 13 years old, and the combination of things I need to do will add up to a lot of money, if I spend the money they HAVE to work. And I still won't have a 3/4 ton. I put a highly advertised Jacobs coil and ignition in it several years ago -- about $300, followed their instructions to the letter -- it did absolutely nothing. I am positive usable power will increase with a gear change to 3.73 -- how much, I don't know.
Allan in NE
05-06-2005 06:54:26
 Re: Yes but..... Re: 700R4/4L60 GM transmissions in reply to CNKS, 05-06-2005 06:19:46
Atta Boy CN!
Shift kits are just like that electronic ignition kit you bought. Stay away from 'em 'cause you are not going to like the result.
The only positive shift kit attribute I have ever seen was the little positive-connection fix on the TV valve to keep it from sticking. That idea at least made some sense. I used to buy those kits, use that one feature and then throw the rest of the kit away.
Other than that, they are nothing more than snake oil marketed at the bubble-chewing hot-rod crowd.
Just my view,
Allan
buickanddeere
05-07-2005 00:42:22
 old wive's tales out there..... Re: 700R4/4L60 GM in reply to Allan in NE, 05-06-2005 06:54:26
The stock HEI ignition system has more than enough capacity to jump the plug gap of a stock low compression, natural aspirated V8 running under 5500rpm on unleaded gas. That said, a high output engine attempting to run 12 to 1 compression at 7500rpm will miss fire with the stock HEI system. This is where the Ultra Mega Turbo Blaster Blitzburg Ignition System" appears to add power. Well no, the ignition upgrade just allows the engine to make it's potential HP that's built into it. Sorry, somebody lied to you about needing your Jacobs system on that truck. There is always someone looking to boost an engines output with just a bigger carb, a straight exhaust stack and premium fuel. It doesn't work. As for shift kits, there are three settings in a kit. What you are thinking of is some 17 yr old *sshole with a sports car half the weight of your truck and twice the HP. The #3 racing shift kit in the kid's car will squeal at every shift while giving whiplash. In your truck the #2 towing kit will gain what you can't feel. Lower oil and clutch temps during shifts due to a shorter slip times. Improved The shift kit will improve your trucks towing performance, don't let any well meaning person tell you otherwise. The Hyper-Tech chips I've used plug right into the ECM/VCM in any computer controled non OBDII vehicle. It's the 95 and later OBDII computers that has the internal E-Prom re-written from an external computer and software. You can alter any parameter you want. There is the "simple" plug in "reprogrammed" that also updates ODBII computers. They stay emissions legal in the idle to 1/2 throttle range where emissions tests are done. These plug into the diagnoticvport and are less flexible but are cheaper and simpler too. The can re-program the high speed limiter and recal the Speedo for different sized tires/axle ratio. The spark timing tables are altered some and the very rich mixtures the factory uses at 2/3 to full throttle to limit power. The mixture is leaned some to peak HP level. After posting last night I thought of what may also work. An adjustable vacuum switch. At some point when the engine is working hard with high manifold pressures. The torque would be unlocked. At part throttle at cruise speeds the toque would lock-up. There is a pin in the diagnostic connector that is tied directly to the lock-up circuit. The circuit is energised when ever the engine is running. When the VCM calls for lock-up, the line running back to the VCM is grounded with a driver inside the VCM. This completes the circuit path and locks the torque. You can operate that lock-up solenoid anytime just by grounding that dash pin. If the brakes are on, you will stall the engine when locking the torque. A Hyper-Tech chip and a towing shift kit will make you as happy as a pig in mud. No cutting or hacking to "jerry-rig" the other solutions.
