Tool Talk Discussion Forum
Lincoln mig welder ?...
mike in New Mex
05-04-2005 11:45:46
Hello- I 've been thinking about getting a mig welder and have been looking at a lincoln 175- I have an arc welder but I want to weld thinner metal. also I have never used a wire welder before. any thoughts or comments ? Thanks-mike
Scott V
05-08-2005 08:13:24
 Re: Lincoln mig welder ?... in reply to mike in New Mexico, 05-04-2005 11:45:46
If you get a Lincoln, spend the extra and get the SP175 plus model. It has a sweet-arc with .023 wire and will weld about as thin as needed.
It belongs in this group of welding machines, as far as being about the top of their class.
I had one and for a small 230 volt welding machine, it's hard to beat!!!!! :)
http://tinyurl.com/96bh5
Loren
05-05-2005 22:56:43
 A heads up for the 110V jobs. in reply to mike in New Mexico, 05-04-2005 11:45:46
I only hear about get the 220V because you'll be happier with it. A big thing to consider if you have a use for it is that the stinger on the little 110 volts jobs can get into places a bigger one can't. I bought mine with that in mind for the occasional exhaust or bracket job. It's been a real saver having it also. If it's your only welder I'd say go to the bigger one though, unless most all of your work is in tight quarters.
mike in New Mexico
05-05-2005 19:41:25
Thanks everybody !! I was looking at a miller but then I saw a lincoln, really haven't made up my mine yet- but will get me a mig for sure ! Thanks again-mike
T_Bone
05-05-2005 07:55:10
Hi Mike,
I agree with the others, get the 230v model as you can turn the amps down to weld thinn metals but you can't turn up a small machine to weld heavy plate.
Try to stay above 200amps on a Mig machine. You will need about 40% duty cycle at 150a to weld a single pass on 1/4" material. You can make multi-pass welds on metal over 1/4" thick just like you do with your stick machine. You will want to stay in the higher amps as you want to keep cold lap to a minimum.
The reason were telling you this, you probably won't want to use the stick machine once you get a decent Mig machine.
Do a search in the archives at the top of this page for welding as there's been some very good past dicussions on Mig welding.
You can't go wrong on Lincoln or Miller Mig machines. Both are excellant quality. I still will not look at a Hobart machine even if it's owed by Miller.
T_Bone
Bartt
05-05-2005 01:30:19
Mike, Just bought a Millermatic 251. WOW doesn't even cover the excitement.Worth paying a little more.
TimV
05-04-2005 18:40:40
Mike: If you have a stick welder, I assume you have a 220-V circuit wherever you"re planning on installing the welder. If so, you"ll definitely be happier with a 220-V unit. Don"t worry about never having MIG welded before--if you can weld with a stick, you can certainly weld with a MIG--90% of the technique is the same, and with a MIG you don"t have a constantly shortening electrode to worry about.
Fawteen
05-04-2005 17:30:29
Me too...
I have a Lincoln SP135, and have no complaints whatsoever. It'll weld a lot more than you think, particularly if you can get at both sides and vee it out and lay multiple beads.
Two observations: IMHO, you'll be happier with a 220V unit, and go with CO/Argon gas rather than flux core for general welding.
Mike M
05-04-2005 12:00:35
I have a very old SP100 lincoln wire welder and it has been very good. You will find that you end up using it for everything. I wish I would of gotten a bigger one,that newer model should be bigger than mine.
jhill
05-04-2005 12:27:06
 Re: Lincoln mig welder ?... in reply to Mike M, 05-04-2005 12:00:35
I have a Lincoln like Mike. My comments exactly. Like it wish it were a little bigger. However the 110 volt feature is very nice.
kjm
05-04-2005 19:10:37
 Re: Lincoln mig welder ?... in reply to jhill, 05-04-2005 12:27:06
Mike I have used three small mig welders Miller and an off brand were 110v the Lincoln was a small 220v. the Lincoln was hands down the best, at least it would weld 3/16 in one pass and is still small enough to pack around. I like Miller brand just because how good is the Lincoln if they sell it at Wally World?
