Tool Talk Discussion Forum
Delta Drill Press
chvet73`
05-03-2005 08:07:08
Got my hands on a Delta 11-990 12" light duty drill press. Didn't pay much for it. I've discovered that the spindle is bent. Now my question is how to get it and the drive pulley apart. The spindle appears to be pressed onto the quill. Do I just press it out or what?
On the drive pulley there's a nut that holds it together. Once it is off the pulley still does not come loose. Is it also pressed on? Any help would be appreciated.
Slowpoke
05-04-2005 02:54:03
 Re: Delta Drill Press in reply to chvet73`, 05-03-2005 08:07:08
My Taiwan model has a tapered shaft on the that drive pulley. Don't loose the nut, it could be a special size, metric 16.5 x ?. But I found a tubing nut will work nicely. Light pounding on the shaft while protecting the threads will work to loosen it.
Tap, tap, tap, tap, tap, etc. Or maybe a gear puller, verrry gently while taping. Don't break the pulley. Use some PB Blaster or similar.
T_Bone
05-03-2005 12:12:00
Hi Chvet,
My cheap 30yr old Tiawanese was bent when I got it and after a few holes the arbor broke just ahead of the chuck (threaded).
I took it apart and welded the arbor but it was nerver just right, about .020 run-out. I bought a dial indicater with a magnetic base and used a dead blow hammer to adjust (knock) the arbor to with-in .001 runout.
So far using a 3-1/4" holesaw and a 7/8" bit, it's kept the .001 run out.
T_Bone
