Tool Talk Discussion Forum
South Bend Lathe
Glen2
05-02-2005 07:41:35
The lathe that I am needing a 3 jaw self centering chuch for has a threaded nose that is 2.25" o.d. with an 8 thread. it has a 8" chuck on it now that isn't self centering. If a 9" would fit that would be OK.Thanks for all your help.
Bud in NC
05-03-2005 04:43:23
 Re: South Bend Lathe in reply to Glen2, 05-02-2005 07:41:35
While you"re looking, check out a "Buck Chuck" - it"s a 3-jaw chuck but you can set the center where you need it like a 4-jaw chuck and it"ll usually repeat once it"s set right.
Ed Weber
05-02-2005 18:26:30
Go to Ebay and type in south bend lathe. They have a 8" 3 jaw chuck up for auction.It closes about 6 days from now. opening bid is 50 bucks. Ed
TP from Central PA
05-02-2005 16:18:04
Enco or MSC should have the chuck you need, I know Enco has the one piece threaded backers still..... .....IMO, a 4 jaw is a bit overkill for most simple/un-precision work.
Gerald J.
05-02-2005 15:50:31
A "self centering" chuck will center within a couple thousandths if new, poorer if worn.
Good machinists prefer the four jaw independent chuck. They use a dial indicator to center the work as close as they desire working to fractions of a thousandth if they are particular.
Then four jaws hold the work more securely than 3, though for round work 6 jaws are even better but a 6 jaw self centering chuck still won't have perfect centering and will cost more than a new South Bend lathe.
The dial indicator you need anyway to see how bad your "new" three jaw is and its lots less expensive than the three jaw chuck.
Gerald J.
Richard Fazio
05-02-2005 15:42:17
What John Garner says 100%. Plus you'll probably want both types if you get into using your lathe. Each has it's purpose. I just got myself an old SB lathe also. You can use what you have right now just to start seeing how your lathe works.
John Garner
05-02-2005 12:46:38
 Lathe Chucks in reply to Glen2, 05-02-2005 07:41:35
Glen2 --
I'm not sure that I'm understanding the problem correctly . . . is it that you have a "scroll" chuck (all jaws move at the same time) that closes substantially off-center, or that you have an "independent" chuck (each jaw move independently) that you have trouble using?
If the first, you should check to see if the jaws are in their correct slots in the chuck body. Scroll chucks usually have three jaws, and all three need to be in the right place in the body for the chuck to close at the center.
The jaws themselves are usually stamped 1, 2, or 3, as are the slots in the body. If the jaws are simply in the wrong slots, you can take the jaws out of the chuck by simply opening the chuck until the jaws come out.
Then, puush jaw 1 into slot 1 while closing the chuck until the spiral "thread" of the scroll engages the jaw; stop closing the chuck once jaw 1 can't be pulled out of the chuck body.
Next, push jaw 2 into slot 2 while closing the chuck until the scroll engages the jaw. As before, stop closing the chuck once jaw 2 can't be pulled out.
Finally, push jaw 3 into slot 3 and close the chuck fully.
If the set of jaws you have just installed properly belongs to the chuck body you have installed them into, the chuck should now hold a workpiece as well centered as that chuck in its current condition is capable of.
If the jaws and chuck body are not marked with the 1, 2, and 3 . . . you just have to experiment.
On the other hand, if you have a 4-jaw independent chuck rather than a scroll chuck, look toward the sky and say "Thank you, God."
An independent chuck is a bit trickier to use than a scroll chuck, but you should it's still pretty easy and offers two MAJOR advantages over a scroll chuck: work can be centered in a "4 jaw" much more exactly than a typical scroll chuck will center the work, and a independent chuck can grasp a solid workpiece much more firmly than a scroll chuck can.
This posting is already getting long, but post back if you need instructions on the use of a 4 jaw and I or another person here will try to talk you through the process.
John
Glen2
05-02-2005 16:02:58
 Re: Lathe Chucks in reply to John Garner, 05-02-2005 12:46:38
I have a indenpendent 4 jaw at this time, and I use a dial indicator, but on some of the small round things that I work on it takes me forever to get it centered. So I am looking for a self centering chuck that I can change to and help speed up the job. I'm not a machinist and only do my own work. Thank all of you for all your help.
dutch
05-02-2005 18:43:06
 Re: Lathe Chucks in reply to Glen2, 05-02-2005 16:02:58
someone before said buy a chuck from msc he is correct if your chuck is out more than .005 is worn a new will put you + or - .002 if spindle brgs and ways are in good condition also check compound rest ways
dutch
05-02-2005 19:05:06
 Re: Lathe Chucks in reply to dutch, 05-02-2005 18:43:06
sorry about that 1 1/2 x9 thread
Jerry Cent. Mi.
05-03-2005 13:33:15
 Re: Lathe Chucks in reply to dutch, 05-02-2005 19:05:06
How about grinding the jaws while the chuck turns. We use to buy soft jaws and machine them for special projects.
