I agree with Dick2 that there is no putty suitable for your purposes. Rather than drilling out the hole and gluing in a dowel, here is what I would do. Find some scraps of straight grain redwood. Using a sharp knife or chisel, split some squares approximately twice the size of the hole. The idea is to fabricate essentially square pegs that have continuous straight grain. Taper the ends of these pegs down to a size that is round and small enough to start in the original screw holes. Using gorilla glue (the polyurethane glue Dick2 mentioned), drive the pegs in as far as they will go. Break or cut off the excess peg down to the original surface. Use an awl to make a start hole for your screws, but do not drill a pilot hole. I arrived at this method after trying numerous other methods in a career of major repairs to antique furniture. Redwood has very long fibers that are pretty strong, yet redwood will compress laterally, this will, in my opinion give you the very strongest bite or new hole possible. If you try my method and find it unsatisfactory for any reason, you can still drill out the hole and use dowel. If you should decide to use the dowel method, use oak or some other hardwood dowel. Do not use birch dowel, as it will deteriorate quite rapidly if any moisture at all reachs it. Good luck. Michael
