Tool Talk Discussion Forum
Hot pressure washer
Gus
04-25-2005 17:36:40
I have an older kerosene type hot water pressure washer. It worked fine when I put it away before winter. I ran some antifreeze through it and drained it. Got it out this spring and found the water coil is plugged. I can bypass the coil and it workes fine. I assume it's rusted up inside. I got the water coil off and have trying to pour muriatic acid in it to eat whatever is plugging it. It only takes a little bit and boils right back out the end I pour it in. Hooked my 160 lb. air compressor to it and that didn't help. Anyone got any ideas? Thanks, Gus.
