Chain-saw Chain Bar oiler troubles, Help.
Canadian Cowboy
01-06-2001 19:50:08
My saw's oiler has been on the fritzs since I bought it new. Its an automatic oiler, It puts hardly any oil on the bar when IM cutting with the saw and a tank full will pour out while sitting over night.
Could it be a faulty oil pump, Ive checked for a leak in the seal of the oil tank, can't find one, cleaned the the oiler out let, adjusted the oiler with the screw on bottom of saw, im stumped as to what to try.
Help.
Ninh Hoa
01-08-2001 14:08:15
 Re: Chain-saw Chain Bar oiler troubles, Help. in reply to Canadian Cowboy, 01-06-2001 19:50:08
Don't know how cold it is where you are, but from the looks of your handle, it could be real cold. Is your saw stored in a heated area? If not, and you don't cut for too long at a time, it could be thick bar oil and a leak between the bar and oiler. Running warms up the saw body and oil. After ya shut it off, the 'warm oil' leaks out. Just a thought.
Jim K
01-07-2001 07:11:33
I would take it apart and look closely for a leak
between the tank and pump or tank and bar.
Jim K
Shep
01-07-2001 06:49:02
Sorry CC -
Can't be of much help here. Would suggest small engine shop look it over if the dealer can't fix it. These guys are generally pretty good "jack of All Trades."
I now use Oregon and Poulan saws with manual oilers - push the button because of the issues witnessed with auto oilers when using my Dad's Homelites (constant auto oiler problems).
