Tool Talk Discussion Forum
calling all machinists
Dieselrider
04-21-2005 18:14:29
This has nothing to do with tractors but you guys are a deverse and far ranging bunch. I have been looking for info on the net but, coming up empty.
I have a Kearney and Trecker 2D rotary head die mill but, no collets for it. They are a double taper collet like the zz collets etc. Does anyone out there know what the proper dimensions are for these and where I might find a set?
Any help would be greatly appreciated.
Ken Towler
01-01-2006 17:45:52
 Re: calling all machinists in reply to Dieselrider, 04-21-2005 18:14:29
I rebuilt a K&T 2D rotary head mill. Collets were not available. If yours has the big nut over the spindle the taper inside is a #30. I bought a common #30 taper collet system from Kennemetal. The K&T collet lock came with an inner piece that matted little double taper collets. It is held inside by a permanant snaprign. No way to get it out. I used a ziz wheel and a dremel tool to cut away pieces of the inner collet. It took some rednecking. I made it into a nut to hold the Kennemetal chuck in place. I also had to turn about .100" of the outside of the Kennemetal chuck so it would fit down into the K&T lockring. The runnout ended up only .00025". Fantastic old machine.
evan j quiros
05-02-2005 07:52:17
Dieselrider--send me ([email protected]) your e-mail or call me 956-791-5810--I don't have any collets for sale but can give you some info and e-mail pictures--evan j
Greg C
04-22-2005 21:45:34
Try practicalmachinist.com
Someone there may be able to help you.
Davis In SC
04-22-2005 04:48:32
It might be worth checking J&L Industrial Supply, they handle Ericson collets. They might be able to cross reference what you need.
MIdwest redneck
04-22-2005 01:59:30
Do a search on the internet for the collets. Then try to call some shops and ask around. My company sold a small chinese lathe and a partial set of 5C collets for $600 to a guy (about a year ago now). Is the machine made by Cross and trecker, Cross and trecker is now Giddings and lewis now I think.
Davis In SC
04-21-2005 18:40:38
Does it have a nut at the spindle nose,instead of a drawbar??? I have seen a K&T rotary mill, but never ran one. It is a versatile machine, you can do almost any thing with it. Angles, arcs, circles, etc...
Dieselrider
04-22-2005 03:59:07
 Re: calling all machinists in reply to Davis In SC , 04-21-2005 18:40:38
It is set up for the nut at the bottom of the spindle but, that too it missing. That piece I'm sure we can build if need be but, would rather buy the collets if we can.
