O-Ring set
Brian G
01-06-2001 16:14:38
Harbor Freight has a 382 piece O-Ring set on sale for $9.99. These O-rings are made of "Nitrile" rubber. Is that the material used in most O-Rings? Is it resistant to motor oils, ATF, hydraulic fluid, fuel oil, gasoline, etc. I have a small collection of O-Rings that I've accoumulated over the years but it seems like many times, I don't have the right size for the job at hand. Is this a pretty good deal? Thanks, Brian
Shep
01-06-2001 20:22:25
 Re: O-Ring set in reply to Brian G, 01-06-2001 16:14:38
I bought an O-ring Service Kit (TISCO# 00718701) for about $20 from my local dealer since everything I own seems to have a leak somewhere. Any of these kits are handy to have around, I strongly recommend them. Fix everything from a Rem 1100 to an Oliver 550.
Shep
big fred
01-06-2001 17:12:32
Yup, Nitrile is what you want. That set has lots and lots of sizes you will never need. The problem is that you don't know ahead of time which ones you don't need, and having extras around is sure cheaper than hopping in the truck to go into town to get that one O-ring that's keeping you from putting something back together. I figure if I just use it a couple times I'm money ahead.
Brian G.
01-07-2001 18:06:33
 Re: Re: O-Ring set in reply to big fred, 01-06-2001 17:12:32
Thanks for the replies guys. I think I'll get the set. It's 10 miles to the nearest Napa dealer. I know that doesn't sound far to you guys out in the midwest, but, Fred makes a good point, it's still a pia when you're in the middle of a project. I was helping a guy out on a spray foam insulation job a while ago and he was using a super duper primer on the galv steel before applying the foam. Anyway the thinner he used for the primer was Heavy Duty stuff and we all used Nitrile gloves. I could hardly believe how they stood up to the thinner.
