Tool Talk Discussion Forum
Air filters
Coloken
04-21-2005 06:57:51
Random thoughts on air filters. All filter will restrict the air flow. Some more, some less. A properly engineered fuel system will take this into acount. Carburators on old cars, computer on new ones. If you remove the air filter you are changing the mixture from what the manufacturer though was right. Yes, some times you can change setting and improve operation. To me the big reason for a filter is to do the best job of filtering posible. THEN, the computer, or what ever should adjust the running at all diferent speeds and loads to the best running possible. Home modifications, like cutting off the small end of the tin work, might help at one speed/load and hurt at another. If a leaky filter increases milage--why not just use the original and put in leaner jets? Some times this works, some times it hurts. If a filter is realy restricting, then it should be a bigger filter. I still liked my Case 930-had a paper filter followed by and old time oil bath for "just incase" some dirt got through.
dr.sportster
04-21-2005 08:08:48
 Re: Air filters in reply to Coloken, 04-21-2005 06:57:51
I remember a fad of turning the air cleaner cover upside down.It gave a deeper sound so lots of youths did this.It also killed the effect of the hot air going into the housing to aid warm-up and gas mileage.The vacuum operated butterfly that helped warm up did not function right either when young guys did this.Sometimes the youth "hop ups" made cars slower.
Ron in Nebr
04-21-2005 08:25:11
 Re: Air filters in reply to dr.sportster, 04-21-2005 08:08:48
Actually flipping the air cleaner lid wouldn't neccessarily make the car "slower". But it would make it run not quite as good and create more emissions until the engine warmed up. Also it would increase engine wear due to the longer warm-up period.
The "snorkle" on factory air cleaners that taper down to a small opening was designed simply to silence the noise. It does that by restricting airflow. When you hear a performance car accellerating, alot of the noise you hear is actually the induction system sucking air instead of all of it being exhaust noise.
Flipping the lid equals more air, and since an engine is simply an air pump- in general more air equals more power. Alot of the factory muscle cars came stock with an open element air cleaner with no heat involved whatsoever.
BUT- in order for the more air to really help, it should also be accompanied by an increase in jet size to allow the air/fuel ratio to remain optimum. The cars that came with the open element air cleaner had carbs jetted to take this into account. The kid who flipped the lid on his dad's monte carlo generally didn't mess with the jetting, and really didn't gain much other than noise.....but then, when you're a kid, a "loud" car is a "fast" car, right? Too bad most kids these days are more interested in the noise coming out of their subwoofer speakers than they are in the noises their engine makes....
