Tool Talk Discussion Forum
Harbor Freight Air Filter/Regulator
Glenn F.
04-20-2005 11:44:39
Air Filter/Regulator Unit, lot# 1118, lists for $39.99. On sale for $24.99. Any good? I currently have my compressor set at 160# and have no regulator for painting or sanders, etc.
Kevin2
04-20-2005 19:30:18
 Re: Harbor Freight Air Filter/Regulator in reply to Glenn F., 04-20-2005 11:44:39
If its that goofy blue thing with the pipe feeding out the side, don"t waste your money. Mine leaks constantly and its design will never allow you to fix. I have a HF mini air filter on the line to dry air for my plasma cutter. 9.99 and I see water condensation in there and cutter works well.
Big Jim
05-04-2005 00:59:32
 Re: Harbor Freight Air Filter/Regulator in reply to Kevin2, 04-20-2005 19:30:18
I've got 2 of the goofy-looking blue ones. One on my breathing air side and one for painting. Never had a lick of trouble with either one. They will also handle a LARGE airflow. The unusual design is because they are a chineese copy of a much more expensive one made by Sharpe.
sylvan
05-08-2005 09:41:13
 Re: Harbor Freight Air Filter/Regulator in reply to Big Jim, 05-04-2005 00:59:32
I had one of those that leaked terribly, so I exchanged it for another. This one doesn't leak as bad, but still, it does leak.
Any suggestions how to fix it so it doesn't?
sdb
