Tool Talk Discussion Forum
air compressors
Jim E Cent IL
04-18-2005 18:05:31
Whai is the difference between, cfm, and scfm? Tools are rated in cfm, and compressors are rated in scfm.
Thanks...
Rod (NH)
04-18-2005 18:42:03
 Re: air compressors in reply to Jim E Cent IL, 04-18-2005 18:05:31
Hi Jim,
CFM is cubic feet per minute and is not a definite quantity when used for a compressible fluid and not supplied with other information at the same time - like pressure and temperature, pressure in particular. SCFM is standard cubic feet per minute and refers to air at "standard" pressure and temperature. Standard pressure is "normal" barometric pressure at sea level elevation, usually taken as 14.7 psi absolute. Standard temperature depends a little in which industry you talking about. In the compressor world, I think it is 60 deg F. In the heating and air conditioning industry I believe it is 68 or 70 deg F. The difference is not significant. Some standards also crank in a moisture (humidity) factor but the compressor industry usually uses "dry" as the standard. For compressors, you can take a standard cubic foot to mean an amount of dry air that would occupy one cubic foot at sea level and "normal" temperature.
Tools are (or should be) rated as some quantity of air at some rated pressure existing at the inlet to the tool. For example, 4 cfm at 90 psig would be a common rating. It is important to note that 4 cfm at 90 psig equals 28.5 scfm assuming the temperature is close to "normal". Tools can also be rated using an "average" consumption" which only confuses the matter as it is generally undefined.
Compressors are normally rated using cfm at the temperature and pressure existing at the inlet opening of the machine. Sometimes this is called inlet cfm (icfm) or "free air" cfm. It is the same as scfm only if the compressor is located at sea level with no inlet restrictions. Although you do see compressors rated in scfm it not technically correct to do so. The scfm capability would then change dramatically depending on compressor location. For example, a compressor "rated" at 10 scfm at sea level would have to be derated by about 20% to 8 scfm if it were to moved to Denver CO due the lower barometric pressure at the higher elevation. The "free air" or inlet cfm would be the same in both locations.
third party image Rod
